rear mount replacement
Old Feb 18, 2008 | 10:05 AM
5genhatch's Avatar
Default rear mount replacement
is it possible to replace this rear mount without having to pull the motor?. what type of tool setups are you using. oh its a 93 hatch with a b18
Old Feb 18, 2008 | 10:14 AM
crazyguy's Avatar
Default Re: rear mount replacement (5genhatch)
yeah u can replace the rear mount without pulling the motor. what i did was , i placed two jacks under tranny and oil pan, removed the long bolt and l pivoted the engine a bit and i also removed T bracket. and removed 3 bolts that hold the rear mount. and installation is the reverse of removal. it is time consuming, but it can be done.
Old Feb 18, 2008 | 10:15 AM
BryanM.'s Avatar
Resident Gearhead
Is possible, but not fun. I did it when I replaced the mounts with HASport units. Loosen the bolts on the other two mounts so you can move the engine around to free up some room. Removing the lower torque mounts will probably give you more free play as well.
Good luck
Mc
EDIT what crazy said sounds better.
Old Feb 18, 2008 | 10:20 AM
n8dizzel's Avatar
Default Re: rear mount replacement (mcvtec)
Not Fun At ALLLLLL. Get another person to help. Makes it way easyer.
1SlowSi
Nov 1, 2008 05:42 AM
t . b o z
Aug 17, 2005 07:45 AM
wizzards581
Apr 8, 2004 09:23 PM
NA-GSR
Sep 20, 2002 07:38 AM
