woohoo!! i made my first turbo manifold!
Old Feb 18, 2008 | 07:25 AM
all_motor_mike's Avatar
Default woohoo!! i made my first turbo manifold!
(other than the couple log manifolds ive done anyways) but its not on a Honda (its for a 4g63) and the pics arent up yet. ill have them up tonight. its just tacked together but i still wanted to know what people thought. i was gonna try a mini ram but it wasnt going to work so then i decided to try another design that i had seen before but i dont see very often. its where the 2 inside runners come up over the top and in to the outside most collector tubes and the 2 outside runners go under the inside runners and the connect to the inner 2 most collector tubes.............. anybody know what im saying and know the name of the design. i was thinking it kinda looked like a "stinger". anyways ill get the pics up as soon as i get off work so u guys can see.
mike
Modified by all_motor_mike at 5:43 PM 2/18/2008
Old Feb 18, 2008 | 09:08 AM
mwieczorek43's Avatar
Default Re: woohoo!! i made my first turbo manifold! (all_motor_mike)
Congrats
Now lets see those pics
Old Feb 18, 2008 | 09:28 AM
random_tuner's Avatar
<--- 4g63
Im not sure what you mean with the design, but pics would help.
Gonna be hard to beat guys like Magnus with manifold design!
Old Feb 18, 2008 | 02:19 PM
Default Re: (random_tuner)
i just checked and yep................. the design is like the one in RC000E sig i hope he didnt design it because now i feel like a cop cat Doh! i mounted the collector in the postion i wanted with a brace and started peiceing stuff together and that is what end up working and being the end result. pics will be up pretty soon here. my plenum design for my intakes are similar to the magnus ones but mine dont blow apart under boost. i couldnt help it. ive never seen there turbo manifolds before .............. well maybe i have but didnt know it. wats it look like?
mike
Old Feb 18, 2008 | 02:21 PM
edited
Old Feb 18, 2008 | 02:40 PM
I was thinking of intake manifolds! My bad. Gotta stop drinkin so much!
Lets see some pics. Whats the manifold flanged for? DSM hotside or a T3/T4 style?
Old Feb 18, 2008 | 04:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by random_tuner &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking of intake manifolds! My bad. Gotta stop drinkin so much!
Lets see some pics. Whats the manifold flanged for? DSM hotside or a T3/T4 style?</TD></TR></TABLE>
the next car that ive got lined up im making an intake and turbo manifold for also......... i think hes wanting to go with a 4294 or 372. but its will be similar to my neon intakes. anyways here the pics of the turbo manifold......... the wastegate outlet off the collector is going to get moved down a bit before its all welded together. well, whatcha guys think???
AMM
Old Feb 18, 2008 | 04:37 PM
manifoldmiketyson's Avatar
Default Re: (all_motor_mike)
looks good.
wastegate transition =
not sure on how many of these you've done, but i would weld colector first then 1 and 4 , then your two smal pieces on the collector on 2 and 3. weld 2 and 3 off the manifold, then finish up with two welds on the head and the collector extensions.
that will make it easer to weld. you won't have to get in tight spaces (besides inside of collector).
i like run-on sentences.
Old Feb 18, 2008 | 05:03 PM
Wow, that does look nice.
Now, heres what Im seeing from my DSM knowledge.
First, is that going to clear the fans?
And 2nd, is it going in a 1g or 2g chassis? (looks like a 1g head which I would hope with that size of turbo )
The reason I ask that is because if that is going in a 2g, youre going to have intake clearance problems with the front tranny mount/x member.
But really man, that looks very nice.
Old Feb 18, 2008 | 05:09 PM
91TSiGuy's Avatar
I'm curious what gen it's going on as well. It seems to sit the turbo pretty low near the front motor mount, and the manifold may have hood clearance issues up top--both problems with a 1g that I can see.
Old Feb 18, 2008 | 06:13 PM
Default Re: (91TSiGuy)
its going in a 1g............. the tubes tha come up sit flush with the valve cover and the front motor mount was an issue........... at most i may have to clearance a little bit of the bracket and the rad and fans are no issue............ hes running an oem rad with slimline fans.
mike
Old Feb 18, 2008 | 07:00 PM
G2turbo_terror's Avatar
Default Re: (manifoldmiketyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manifoldmiketyson &raquo;</TD></TR><TR><TD CLASS="quote">
Yup. Very sexy. Are you willing to share how you made that cut? Any plans for a V-band DP?
Old Feb 18, 2008 | 07:51 PM
.RTErnie's Avatar
Default Re: (G2turbo_terror)
Excellent fit up. Good bevel...nice joints. Now lets see you weld it
Old Feb 18, 2008 | 08:02 PM
Default Re: (.RTErnie)
i know........... i like the way it looks unwelded lol! i think ill do alright.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2turbo_terror &raquo;</TD></TR><TR><TD CLASS="quote">
there was no secret about that damn cut it kicked my ***. i cant really explain it because i dont know how to but i did use a belt sander quite a bit on the end where the belt turns because its very narrow there and i could sand some curves into it.
AMM
Old Feb 19, 2008 | 03:59 AM
oh and question about the rod to be used.........
i should should 308 rod for the stainless to stainless welding and 309 for the mild to stainless welding correct. any other rods ok for use cause my local store dosent stoock 308.
mike
Old Feb 19, 2008 | 04:51 AM
HT Chaplain's Avatar
Loved
What did you use to make the cuts??Be sure to post pics of the finished welds
Old Feb 19, 2008 | 09:39 AM
Running925's Avatar
excelent work on the wastegate connecting pipe.. the trick to it should have been to just use a plasma cutter! Then just smooth it all out
Old Feb 19, 2008 | 09:48 AM
mrbsponge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motor_mike &raquo;</TD></TR><TR><TD CLASS="quote">oh and question about the rod to be used.........
mike</TD></TR></TABLE>
i thought it was 309 for stainless to stainless and 308 for mild and stainless andf 316 for just about anything/
very nice looking BTW,
Old Feb 19, 2008 | 10:07 AM
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain &raquo;</TD></TR><TR><TD CLASS="quote">What did you use to make the cuts??Be sure to post pics of the finished welds </TD></TR></TABLE>
i used a band saw and a few times a sawzall with some torch blades which the stainless still ate up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Running925 &raquo;</TD></TR><TR><TD CLASS="quote">excelent work on the wastegate connecting pipe.. the trick to it should have been to just use a plasma cutter! Then just smooth it all out </TD></TR></TABLE>
thanks, and unfortunately i dont have or have access to a plasma cutter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">
no its 308 for stainless to stainless and 309 for stainless to mild. and for anyone......... would there be any issues with welding this thing together with 309 rod???
and last but not least................ what is the nick name given to this design of manifod???
thanks
mike
Old Feb 19, 2008 | 03:23 PM
use 309 .045 for the pipe and jump it up to 3/32 for the pipe to flange. 309 comes out a lot cleaner then 308 or 316.
Old Feb 19, 2008 | 03:27 PM
AMM</TD></TR></TABLE>
Cool. Thats what I suspected. I zoned out today thinking about this and came up w/some ideas that I'm anxious to try out.
Old Feb 19, 2008 | 03:41 PM
Kevin's Avatar
Damn, looks good so far. That's exactly how i want to do the wastegate transistion on my manifold.
Old Feb 19, 2008 | 04:33 PM
thermal's Avatar
impressive cuts... WG transition is awesome!
Old Feb 19, 2008 | 05:07 PM
thanks guys.............. and Mike............. so i can use the stainless to mild rod to weld stainless to itself with out having any issues down the road???
AMM
Old Feb 20, 2008 | 06:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motor_mike &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys.............. and Mike............. so i can use the stainless to mild rod to weld stainless to itself with out having any issues down the road???
i'm assuming you asking me? either way, yeah, i've never had an issue using 309. only thing i guess i'm forgetting is that if you using 316 pipe, i would us 321 rod. usually you want to step up one grade for the rod.
in fact, i don't think i'm going to be stocking 308 rod anymore at all.
sometimes its harder to get 309 rod locally depends on the welding supply shop or they only offer it in 3/32 and thicker.
my local place has .045 in stock
