what should i do first?
Old Feb 18, 2008 | 07:12 AM
mybabyls's Avatar
Default what should i do first?
i have a 91 integra ls with 177,000 miles, already put a cold air intake and getting a stage 3 clutch next, what should i do after?
Old Feb 18, 2008 | 12:43 PM
94DB8's Avatar
why did you get a stage 3 clutch?
...header
Old Feb 18, 2008 | 01:54 PM
GSR in progress 96's Avatar
* B A N N E D *
Return clutch and do a tune up
Old Feb 18, 2008 | 02:08 PM
1dumbscreenname's Avatar
Default Re: (GSR in progress 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR in progress 96 &raquo;</TD></TR><TR><TD CLASS="quote">Return clutch and do a tune up</TD></TR></TABLE>
heck yeah. all new fluids (brake, PS, Coolant, Oil etc)filters, brakes (rotors, and pads and check brake lines), cap rotor, lines and plugs. then you can move forward. also do a leakdown and compression test to see how healthy your motor is.
Old Feb 18, 2008 | 02:17 PM
iBear's Avatar
Default Re: (1dumbscreenname)
Seriously. Why a stage 3 clutch?
Do some maintenance and a tune up.
I'd get a decent suspension setup after that.
Old Feb 18, 2008 | 05:42 PM
friesx100's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1dumbscreenname &raquo;</TD></TR><TR><TD CLASS="quote">
also do a leakdown and compression test to see how healthy your motor is.</TD></TR></TABLE>
Im kind of rogue when it comes to all of this; is there any reccomended or right/wrong place to get this done? And how much does it generally cost for a full fluid flush, and the tests mentioned?
Old Feb 18, 2008 | 07:08 PM
Default Re: (friesx100)
you can do the compression test easily the gauge is like 30 bucks at autozone so go ahead and do it yourself. the leakdown is a bit harder so just go to your fav mechanic and they will do it for you.
these are from the civic forum but they are all the same.
for leakdown test
https://honda-tech.com/zerothread?id=1491041
the rad flush. easy.
https://honda-tech.com/zerothread?id=1424191
heres how to do the compression test
IN OUR OWN FORUM!!!
https://honda-tech.com/zerothread?id=76154
if you just want to pay someone expect about 150-200 for everything.
Old Feb 18, 2008 | 07:11 PM
found more info for a leakdown.
https://honda-tech.com/zerothread?id=438893
Old Feb 20, 2008 | 07:38 AM
mybabyls's Avatar
Default Re: what should i do first? (mybabyls)
well i wa going to get the clutch cause my stock one is starting to go out, just changed the oil n filters need to do compression and leakdown, how much would a leakdown cost?
Old Feb 20, 2008 | 08:48 AM
EddieR's Avatar
From: Why, so you can steal my shit, damn noobs, usa
Default Re: (iBear)
after tune up, do some supsension mods.. no need in all that power if your car handles like crap.
Old Feb 20, 2008 | 09:12 AM
jomama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by friesx100 &raquo;</TD></TR><TR><TD CLASS="quote">
Im kind of rogue when it comes to all of this; is there any reccomended or right/wrong place to get this done? And how much does it generally cost for a full fluid flush, and the tests mentioned?</TD></TR></TABLE>
not the greatest attitude. if that's the case, strap on some NAWS and see how your engine will run. seriously, on a 91 with that many miles, take care of maintenance issues first. i bought a 96 gsr 1ith close to 200k on the motor as a daily and i'm dealing with all sorts of maintenance gremlins.
Old Feb 20, 2008 | 03:24 PM
projectGS-R's Avatar
Default Re: (jomama)
i agree maintance first
Old Feb 21, 2008 | 01:59 PM
mybabyls's Avatar
Default Re: (projectGS-R)
alright thanks guys, and outa curiousity what kind of turbo would be the best for my car?
MisterNiceGuy
Honda Civic (2006 - 2015)
14
Aug 19, 2007 07:10 PM
Importracer_001
Mar 20, 2006 07:35 AM
bOOsTiNSoHcVtEc
Jul 7, 2005 03:22 PM
11psiTurboSI
Jun 5, 2005 08:30 PM
HybridGSR1
Jul 24, 2003 07:15 PM
