EG rear upper control arm, same as integra?
Old Feb 18, 2008 | 06:58 AM
Magick211's Avatar
Default EG rear upper control arm, same as integra?
EG rear upper control arm, same as integra rear uca? I did some searching and didnt come up with much, The reason im asking is that a friend of mine just put his teg back to stock height and is no longer in need of his rear ajustable uca's and he is willing to trade me straight across
Old Feb 18, 2008 | 11:14 AM
d16efsedan's Avatar
Default Re: EG rear upper control arm, same as integra? (Magick211)
TTT
Old Feb 18, 2008 | 08:49 PM
BlueIntegraBoy's Avatar
Yes, it's the same
Old Jun 6, 2008 | 04:41 AM
gamakichi77's Avatar
Default Re: EG rear upper control arm, same as integra? (BlueIntegraBoy)
how about front upper arms of TEG (DB9) can be used at EG6(SR3) as well?...
Old Jun 6, 2008 | 05:20 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: EG rear upper control arm, same as integra? (gamakichi77)
The YEARS of the cars being discussed will help too. I'm not 100% polished on Integra chassis codes, so I'll assume DB means 90-93 Integra.
90-93 Integra = not the same front upper arm as 92-95 Civic
94-01 = same front upper control arm as 92-95 Civic
Old Jun 6, 2008 | 05:40 AM
Default Re: EG rear upper control arm, same as integra? (B18C5-EH2)
but, the code engraved on the DB's upper arm is SR, same as per 92-95 civic...still curious...anybody got experience?
Old Jun 6, 2008 | 05:41 AM
B18C5-EH2's Avatar
Former Moderator
Loved
What YEAR is the car?
Old Jun 6, 2008 | 05:44 AM
B18C5-EH2's Avatar
Former Moderator
Loved
BTW I've got plenty of first-hand experience with this.
I don't have time to look up the chassis code and see what year car you're talking about.
It's very simple - 90-93 is not the same; 94-01 is the same.
If you do not believe me on the years then ask yourself why Skunk2 has a completely different upper control arm camber kit for 90-93 Integra/EF Civic and then a 94-01 Integra/92-95 Civic kit.
Old Jun 6, 2008 | 06:15 AM
i'm not sure from what year is that DB9's upper arm, either 93, 95 or 99...i bought the used parts from the "reconds parts" shop. The seller only know its DB9. i'm not sure either it can be used on my 92hatch (SR3)...
Old Jun 6, 2008 | 06:21 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I'll look up DB9 - it might be a 4 door 94 style chassis.
Old Jun 6, 2008 | 06:25 AM
i'd just do some search....DB9 is 2 and 4 doors from 93, 95 and 99 TEG..
Old Jun 6, 2008 | 06:39 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I've got all the USDM VIN specs here in front of me in a Genuine Acura Parts quick refernce guide, and there is no DB9 which means it's probably a JDM or overseas code, BUT it looks like it would be the 94-up style judging by the USDM codes for 94-up being DB7, DB8 etc.
All the USDM 90-93 Integra 4 doors look to be DB1 - nowhere near DB9.
*edit*
I'm sure someone has a chart including JDM codes so you can see that DB9 is a certain year.
Modified by B18C5-EH2 at 10:51 AM 6/6/2008
Old Jun 6, 2008 | 06:49 AM
DB9 is JDM...i did saw few units of chassis in my country, malaysia, DB8 and DB9...but, this upper arms, i do not sure either can fit to my sr3...
Old Jun 6, 2008 | 06:51 AM
anyway, thanks for your info pal..tommorrow i will try to install it on my 92 hatch...if fit, i will tell it here...
Old Jun 6, 2008 | 09:23 PM
done it...just installed the upper arms from DB9 into my SR3...and now still installed my new steering rack...thanks pal...
Old Jun 7, 2008 | 09:40 PM
just install my steering rack...no more freeplay on my steering wheels...but, still got another sounds coming out...is it due to my front lower arms?...drive shaft been replaced to new sets 3 months ago. which bushing of front lower arms should to replaced?...
vincent001
Suspension & Brakes
Sep 25, 2006 10:46 AM
92integraVTECgsr
Feb 21, 2006 08:31 PM
Blade_Irl
Aug 27, 2004 08:09 AM
