spoon ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harry007 »</TD></TR><TR><TD CLASS="quote">does the original spoon ecu disable both o2 sensors? should do as its using its own fuel curve etc...? i am noob lol.</TD></TR></TABLE>
You are a noob at Honda's, or typing sentences?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harry007 »</TD></TR><TR><TD CLASS="quote">erm re-read it mate. your not answering my question.</TD></TR></TABLE>
If you want ?'s answered, at least take the time to type a complete sentence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harry007 »</TD></TR><TR><TD CLASS="quote">what is this skool?
Hi I have a spoon ecu, I would like to know if it disables reading from the two o2 sensors?
Kind Regards
Harry
No this is not "Skool", but that is not an excuse to make illiterate sentences out of laziness. I would guess that the Spoon ECU does not disable the O2 sensors, as there would be no benefit in doing so, but I do not know for sure.
Kind Regards
Harry
</TD></TR></TABLE>No this is not "Skool", but that is not an excuse to make illiterate sentences out of laziness. I would guess that the Spoon ECU does not disable the O2 sensors, as there would be no benefit in doing so, but I do not know for sure.
Harry,
I would venture to say, "No", it does not disable the O2 sensors. The O2 sensors only give fuel/ratio information to the ECU. This information is VERY important to running the motor efficiently. They only give info, it is up to the ECU what it does with that information. A fuel curve is worthless unless the ECU can monitor how that curve is affecting the engine output, which it partially does with the info from the O2 sensors.
I hope I was able to shed some light on your question.
EFOSV.
10
Jul 3, 2006 08:25 AM
