b16 pistons in a ls build?
Old Feb 17, 2008 | 11:54 PM
SIC_DA9's Avatar
Default b16 pistons in a ls build?
can i put b16 pistons into my ls build without the expensive dyno tuning at the end? if so will it run right with ls crank and rods?
Old Feb 18, 2008 | 07:53 AM
racebucket_eg's Avatar
Default Re: b16 pistons in a ls build? (SIC_DA9)
Why would you want to put the time and money into installing pistons but not want to dyno tune it to get the max potential out of your set-up? IMO with this mentality you probably shouldn't be modding a car.
To answer your question, yes, it will work with the LS crank and rods..... tons of people have done it. It wouldn't be a bad idea to replace the factory rod bolts with arp's while you are at it.
Old Feb 18, 2008 | 08:22 AM
sph33r's Avatar
Do the math.. it's like a 2 point compression bump. No way you'll be able to get away with this without tuning.
Old Feb 19, 2008 | 05:06 AM
00MRSi's Avatar
Default Re: (sph33r)
lol. like mentioned, why would you not want to get it tuned?
Old Feb 19, 2008 | 10:04 PM
SIC_DA9's Avatar
ok ok damn.i jus heard otherwise. u HT guys really try and slam people for no reason (racebucket)
jeeez.
i like sph's answer better.
Old Feb 20, 2008 | 07:31 PM
aholeb16's Avatar
Default Re: (SIC_DA9)
i love people who find it so easy to judge someone based upon a simple question. i had asked a similar question in another post. you should find a p28 ecu and adaptor harness, and get a basemap chip/ or dyno tuning. for longevity/reliability, there really isn't any way around it.
a1320honda
Jan 14, 2009 06:30 AM
CO_CReX
Apr 26, 2006 11:03 PM
hOndafienD 04
Apr 6, 2005 08:42 PM
andrewbolton
13
Apr 2, 2005 01:12 AM
Goldfingiz
Nov 24, 2002 04:42 PM
