Tinted Windows help
Old Feb 17, 2008 | 07:16 PM
414teg95ls's Avatar
Default Tinted Windows help
the guy hwo owned the crx before me tryed tinting the windows him sle fand two toned it how do i get that crap off?
Old Feb 17, 2008 | 07:37 PM
Targa250R's Avatar
be professional
Default Re: Tinted Windows help (414teg95ls)
Old Feb 17, 2008 | 08:34 PM
APEX CRX's Avatar
Default Re: Tinted Windows help (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
HAHA thats some funny ****
Old Feb 17, 2008 | 08:37 PM
CoolRedXylophone's Avatar
I had the same problem when I got my CRX. Use razorblades like previously stated and some windex. It helps get the glue residue off.
welfarepc's Avatar
i found brake cleaner helps losen the tint up, and when you scrape with the single edge razor scrape at an angle it will go much faster
Modified by welfarepc at 12:24 PM 2/18/2008
Old Feb 18, 2008 | 07:54 AM
darklyte's Avatar
if you have a steamer hold the steam up to it ,let the steam warm it up and then start peeling it right off.slow process but it works the best.
Old Feb 18, 2008 | 07:57 AM
Ratster's Avatar
No steamer ? Heat gun or hair dryer worked good for me.
Old Feb 18, 2008 | 11:36 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
The best way is using a solvent of sorts. how powerful is up to you, I used to use KING solvant, came in a huge black spray can. Anything else is way too much work. heat / steam works well to get an edge started, but steam also reactivates the glue so it sticks to w/e you're trying to wipe it with, and razor blades are overkill once you get an edge started and its also a great way to make your rear defroster broken.
Old Feb 18, 2008 | 01:00 PM
sam0218's Avatar
i had the same problem. i took the windows out then poured ammonia on the tinted side, covered them in trash bags then let them sit in the sun. i came back about an hour later and it peeled right off
Old Feb 18, 2008 | 01:04 PM
JJ's civic's Avatar
Default Re: Tinted Windows help (sam0218)
i work at a *** shop where we do pro tint and the way we take it off is you pull the corner off and jsut peel the tint off then you spaary wondoew clean and scrap the glue off. or you can use amonia 50/50 water on the window and he will come off with a rag after like 30 mins of a soak.
Old Feb 18, 2008 | 01:42 PM
SuM Honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam0218 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem. i took the windows out then poured ammonia on the tinted side, covered them in trash bags then let them sit in the sun. i came back about an hour later and it peeled right off</TD></TR></TABLE>
x2 kinda. get trash bags and windex, spray the window with windex and stick the trash bags to the window. let bake in sun for 30-45 minutes. peel whole sheet off at once. clean window. BTW it was to be warm for this to work.
Old Feb 18, 2008 | 02:11 PM
sky9's Avatar
u can use some goo gone and a razor blade, works fine for me but takes some time. gl
Old Feb 18, 2008 | 02:55 PM
pjr710's Avatar
Default Re: (sky9)
get a razor blade, and try to take off as many big full pieces as possible, when you take off the tint, respray the tint with some water and a little soap mixed in, put the tint back on the window and let it sit for like 20-30 mins, and then take it off, that will take most of the glue off of the window.
If you still have glue on your window after that.. get a razor blade, with a razor blad holder, spray your window with soapy water, and run ur hand up and down the window with the razor blad, like a squeegee, until the glue is off
Old Feb 18, 2008 | 08:23 PM
SuM Honda's Avatar
Default Re: (sky9)
If you use a razor blade, don't expect to have a defroster afterwards.
Old Feb 18, 2008 | 08:42 PM
x4thGenCafe's Avatar
OF THE KINGS
thats what I used
Old Feb 26, 2008 | 08:02 PM
414teg95ls's Avatar
Default Re: (x4thGenCafe)
if i use a raz blade why woudlnt i have a defroster afterwards
Old Feb 26, 2008 | 08:21 PM
Targa250R's Avatar
be professional
Default Re: (414teg95ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 414teg95ls &raquo;</TD></TR><TR><TD CLASS="quote">if i use a raz blade why woudlnt i have a defroster afterwards</TD></TR></TABLE>
If you cut the defroster traces with the blade, you break the circuit. No more defroster.
Old Dec 11, 2008 | 10:47 PM
acmoc's Avatar
Can you tint the rear window from the outside?
Old Dec 11, 2008 | 11:14 PM
ThA IntegrA HI's Avatar
sure y not
Old Dec 13, 2008 | 07:33 PM
acmoc's Avatar
Originally Posted by ThA IntegrA HI
sure y not
OK, you're not being sarcastic are you?
Anyone ever use those pre-cut do it yourself
Old Dec 13, 2008 | 07:42 PM
ej1serge's Avatar
lol hes sayin yes u can but it wouldnt be right.. with weather and just regular wear n tear itll come off eventually or bubble faster..
Old Dec 13, 2008 | 09:30 PM
acmoc's Avatar
Oh yeah, =[ my baads, I'll just use the cheap wal mart stuff from walmart on that one then and re'do it every summer
metal
Apr 2, 2008 03:48 AM
rhdef8
Nov 3, 2005 05:49 PM
CRX Si
Mar 28, 2005 09:15 PM
AIWFCIATR
Jan 7, 2005 07:33 PM
Steve91
Jul 20, 2003 09:27 AM
