driver side wheel toed in about 2-3 inches replaced tie rod end and not much better HELP
Old Feb 17, 2008 | 06:01 PM
Untamed_Hatred's Avatar
Default driver side wheel toed in about 2-3 inches replaced tie rod end and not much better HELP
I was doind about 70 into a fairly easy turn and i hit a fresh patch of dust and lost control and slid into a curb now my lower control arm support is bent and my driver side tire is toed in about 2.5 inches. i was told ot replace the tie rod end and move from there but its still pretty bad. and advice on what i should do
Old Feb 17, 2008 | 06:10 PM
Targa250R's Avatar
be professional
Default Re: driver side wheel toed in about 2-3 inches replaced tie rod end and not much better HELP (Untame
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Untamed_Hatred &raquo;</TD></TR><TR><TD CLASS="quote">I was doind about 70 into a fairly easy turn and i hit a fresh patch of dust and lost control and slid into a curb now my lower control arm support is bent and my driver side tire is toed in about 2.5 inches. i was told ot replace the tie rod end and move from there but its still pretty bad.</TD></TR></TABLE>
Umm, yeah . . . you're probably going to have to replace the entire rear crossmember (with attached LCAs), and pray that the frame isn't bent. Hopefully you didn't bend the radius rod or knuckle and damage the steering rack either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">advice on what i should do</TD></TR></TABLE>
You should think twice before speeding like a retard on public roads next time, because this is exactly what happens. Luckily you didn't hit some innocent passer-by on the road and injure them.
Old Feb 17, 2008 | 06:14 PM
wasnt a public road was private (for now) friend of mines kinda. we had permission to be back there. i know abou the rear im just gonna get it pulled when i get the money.
the road is like 5 miles long. we legally street race back there. i was just having fun but it was prob a bad idea from the beginning
Old Feb 17, 2008 | 06:17 PM
zrickety's Avatar
The easiest thing to do is get under the car and measure some landmarks on the 'good' side of the car. For example, from the lower ball joint nut to the front crossmember. Then compare these measurements with the side you hit and try bending, hammering, or moving what needs to be adjusted, depending on the parts. This is what I had to do when some bolts broke on my Full Race traction bars. The more measurements you take, the better off you'll be. Good luck!
Old Feb 17, 2008 | 06:24 PM
thanks man
Old Feb 17, 2008 | 06:37 PM
zrickety's Avatar
Default Re: (Untamed_Hatred)
welcome! if it's a CRX, i have a .pdf honda manual i can email you. it has all the frame measurements, though i've always just measured the car and made sure both sides were the same
Old Feb 18, 2008 | 04:44 PM
yeah man that would be great. email is nicholasprutz@msn.com
Old Feb 18, 2008 | 06:41 PM
zrickety's Avatar
i just sent it, it's a big file called the 'VTEC Supplement.' what you want is under 'frame repair.' i'm curious what you'll find on the car, let us know!
corpsebesideme
11
Aug 21, 2016 01:11 AM
Hexar
Oct 14, 2009 02:33 PM
gsr2envy
Nov 8, 2004 11:58 AM
::MYCORD::
Oct 2, 2004 12:01 PM
