Turn signal issues...
Obviously, I need help. My turn signals do not work on my car. I have checked all my fuses and grounds and still nothing. I have replaced my hazard switch and still nothing. I have searched on here for any clues as to what is wrong, but I haven't found anything out. Does anyone have any ideas?
I don't know. I have an idea that it may be the relay. This would be an easy fix for me any other time, but seeing as how my ex-boyfriend the Honda guru is up in Michigan and I'm stuck in stinkin' Florida... there's only so much you can do over the phone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irishhonda »</TD></TR><TR><TD CLASS="quote">but seeing as how my ex-boyfriend the Honda guru is up in Michigan and I'm stuck in stinkin' Florida...</TD></TR></TABLE>Prepare yourself to receive more responses than you want...
But you're gonna have to help us by telling us what's wrong with your turn signals... Are they in rapid-blink mode? Does one or more of your corners not light up? Do the turn signal indicators in your gauge cluster light up? Do you hear the relay clicking? Did you use a multimeter/test light to check your fuses & grounds? What was the most recent change (if any) to your wiring (any new parts related to your lights)? Are all of your bulbs working?
Help us help you
JasonGhostz
<FONT COLOR="white">NINJA</FONT>Oh yeah, you might want to tell us what kind of car you have... (year, make, model, #doors, trim level, mods)...
Help us help you
JasonGhostz
Hmm... that would help, wouldn't it? They do absolutely nothing. Nothing lights up in the dash, no corner lights... nothing. The grounds are fine, nothing is done to the car... fuses are all fine as well. And I don't hear any clicking.
And my car is a 95 Honda Civic coupe DX, manual... bone stock and slow as hell.
i used to have the same problem and i replaced the switch assembly behind the steering wheel(couple screws and the lights and wiper switch slides off in one. after you take the steering wheel off) does the blinker switch lock in when you push it down or up?
Roofrack
Oct 2, 2008 09:10 PM
Agent Daimon
Apr 30, 2007 10:29 AM
Quik89Si
Dec 24, 2005 06:55 PM
