B Series Axle Length
Old Feb 17, 2008 | 05:26 PM
JoHA's Avatar
Default B Series Axle Length
Well my main problem last year was my axles, going from brand new to that beautiful clicking noise they make shortly before they fail in 2-3 weeks.
I have been using the standard integra axles that do work with my swap (B18C1 into EJ6), but I guess I am looking for something that can help prevent my axle issues.
I attribute the majority of my issues to the car being lowered and the camber being corrected. When it is lowered and corrected it seems like the axle is a little too long, so the outer boot is slightly bent and ultimately stressed more than it should be.
Put simply I am wondering if the civic si (b16) axles are the same length as the integra ones, and if anyone knows if the "b series swap" axles are the same as well.
If I have no other choices I guess I will just raise the car up a little and throw some camber at it to try and straighten the axle as much as possible.
Short Version:
Are b16 and other b series swap axles the same length as integra axles?
Old Feb 17, 2008 | 05:46 PM
JDM-EJ698's Avatar
Default Re: B Series Axle Length (JoHA)
Yes they are the same.The diferent ones are 90-93 tegs.I run 99-00 si ones.but I've got integra spares and they are the same length.What issues are you having?
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoHA &raquo;</TD></TR><TR><TD CLASS="quote">
yes.but only 94 and up integra's
Old Feb 17, 2008 | 05:55 PM
JoHA's Avatar
Default Re: B Series Axle Length (JDM-EJ698)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 &raquo;</TD></TR><TR><TD CLASS="quote">Yes they are the same.The diferent ones are 90-93 tegs.I run 99-00 si ones.but I've got integra spares and they are the same length.What issues are you having?</TD></TR></TABLE>
The issue is basically no matter what type of driving I do on them, the axle will separate from itself inside of the outer boot, both driver and passenger sides have failed multiple times. I can expect when racing on them, especially now that Im running higher power levels than before, that the stock axles will fail, but even babying them I am still having the problem where they begin to fail.
Like I said I will probably just end up raising the car up a bit and throwing some camber at it until the axle is as flat as can be.
Thanks for the response guys
Old Feb 17, 2008 | 06:05 PM
JDM-EJ698's Avatar
I have no issues and my car is slammed.Wheels tucking.but I have NO camber issues.Maybe bad axles?I use advanced auto axles.(lifetime replacement. )
Old Feb 17, 2008 | 06:15 PM
JoHA's Avatar
Been using virtually the same things, i may just go to advanced and get some new ones and just keep the ones i have right now as backups.
Old Feb 17, 2008 | 08:36 PM
slvrlude's Avatar
as with what everyone else is saying, they are the same....i have a B16 in my eg and i'm using the axles out of a del sol.....but anyway, a possible solution if you have the time and knowledge, is you can swap out the outer boot and bearing from the B series and replace it w/ your stock civic boot and bearing. and when I say bearing, i dont mean wheel bearing, i mean axle bearing. correct me if i am wrong guys
Old Feb 17, 2008 | 08:59 PM
USDMCIVICHATCH's Avatar
Default Re: (slvrlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrlude &raquo;</TD></TR><TR><TD CLASS="quote">as with what everyone else is saying, they are the same....i have a B16 in my eg and i'm using the axles out of a del sol.....but anyway, a possible solution if you have the time and knowledge, is you can swap out the outer boot and bearing from the B series and replace it w/ your stock civic boot and bearing. and when I say bearing, i dont mean wheel bearing, i mean axle bearing. correct me if i am wrong guys</TD></TR></TABLE>
the stock civic boot and bearing is the same....
kuja396
Aug 30, 2007 08:21 AM
ak_teg92
Mar 22, 2007 02:27 PM
whitehf
Dec 7, 2004 02:08 PM
