b18b cranks but wont start
Old Feb 17, 2008 | 02:22 PM
matmcg's Avatar
Default b18b cranks but wont start
things done so far - replaced distributor
car still cranks but wont start
What can i do?
Old Feb 17, 2008 | 02:58 PM
blkb18's Avatar
Default Re: b18b cranks but wont start (matmcg)
are you getting fuel? Are you getting spark?
Old Feb 17, 2008 | 03:17 PM
m735is's Avatar
Try spraying starting fluid in the inatke. Does it start for a few seconds?
Can you hear the fuel pump prime for a couple of seconds when you turn the key?
Old Feb 17, 2008 | 03:19 PM
guy_from_nerk's Avatar
Default Re: b18b cranks but wont start (m735is)
Check timing!
Old Feb 17, 2008 | 03:20 PM
yc_dc4mar's Avatar
did you put the spark plug wires in the correct order?
Old Feb 17, 2008 | 03:21 PM
matmcg's Avatar
all it does is crank
if i listen for the fuel pump and it primes does that mean the fuel pump is oaky/?
Old Feb 17, 2008 | 03:26 PM
Default Re: (matmcg)
yeah if its priming odds are the pump is fine. Make sure you got the wires in order 1342 is the firing order.
Old Feb 17, 2008 | 03:29 PM
Deluzional's Avatar
Default Re: (guy_from_nerk)
time to replace that starter
Old Feb 17, 2008 | 03:34 PM
matmcg's Avatar
i doubt the car will turn on even if i push start it
the starter works still im sure
when the battery isnt being boosted i hear the starter clicking
Tofuboi55
Apr 24, 2018 11:14 PM
lif3tak3n
Jun 24, 2014 06:00 AM
jdavis94teg
May 12, 2009 09:28 AM
devin_hoang
11
Dec 31, 2008 06:01 PM
DA_zooooms
May 12, 2008 07:16 PM
