Help with swap problem!
Old Feb 17, 2008 | 01:43 PM
andit10's Avatar
Default Help with swap problem!
I recently swapped a gsr into my eg civic coupe and whenever i put it in fifth gear, the gear will stay in for bout 30 seconds and then just pop out into neutral...i was thinking that it might be because i currently don't have a rear engine mount on there...or could it just be that the transmission is bad?
Old Feb 17, 2008 | 02:38 PM
chuisek9's Avatar
Default Re: Help with swap problem! (andit10)
the synchronizer is bad!!
Old Feb 17, 2008 | 04:17 PM
z6hatchboy's Avatar
Put the rear mount on it, when in 5th gag it some and see if it pops out. The engine could be rocking and popping it out of gear. 5th doesnt see that much abuse and if you dont hear it grinding then it may not be the trans.
Old Feb 17, 2008 | 04:36 PM
.I.Need.Money.'s Avatar
Have you tried flushing your tranny fluid? Fifth gear is the highest on the set inside the housing, so it's the first to be dry when low on fluid.
Old Feb 17, 2008 | 06:49 PM
ek4_b16a's Avatar
Default Re: Help with swap problem! (93EGB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried flushing your tranny fluid? Fifth gear is the highest on the set inside the housing, so it's the first to be dry when low on fluid.</TD></TR></TABLE>
what he said...and what the other guys stated...and why don't you have a rear mount on the car? you have hasport mounts or what? sheesh...so unsafe there buddy...put it on, put more tranny fluid in and see what happens next...
Fat Chick Magnet
Dec 5, 2007 10:59 AM
indtegra
Nov 5, 2007 07:22 AM
TrueDC2
Oct 3, 2003 12:13 PM
d_mina
Jul 24, 2003 03:47 PM
chuteBOXE
Apr 13, 2003 02:34 PM
