AC AUTOTECHNIC fuel rail fitting size needed....
Old Feb 17, 2008 | 01:22 PM
alscrx's Avatar
Default AC AUTOTECHNIC fuel rail fitting size needed....
Does anyone know from experience the inlet fitting size on the AC Autotechnic fuel rail for the b motors???? It comes with a fitting for the stock banjo but i wanna use some AN fittings.
I needed to order some fittings for my braided steel hose setup.....i need to know the inlet fitting size please
Old Feb 17, 2008 | 06:09 PM
djtsmith007's Avatar
Default Re: AC AUTOTECHNIC fuel rail fitting size needed.... (alscrx)
ask AC
Old Feb 17, 2008 | 06:32 PM
jhammond_82's Avatar
Reject Papi
Default Re: AC AUTOTECHNIC fuel rail fitting size needed.... (djtsmith007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtsmith007 &raquo;</TD></TR><TR><TD CLASS="quote">ask AC</TD></TR></TABLE> sounds like a good idea to mee!!
Old Feb 18, 2008 | 08:00 AM
alscrx's Avatar
Default Re: AC AUTOTECHNIC fuel rail fitting size needed.... (jhammond_82)
Thanks but i sent them an email and got no response!
Old Feb 18, 2008 | 10:23 AM
see if you can give them a call
Old Feb 18, 2008 | 03:21 PM
alscrx's Avatar
Yeah i called AC and the guy said he has no idea what size it is.....what a dummy!
I didn't want to have to remove the fuel rail again because they leak when removed.....
Old Feb 25, 2008 | 09:07 PM
alscrx's Avatar
bump for help!!!
Old Feb 25, 2008 | 09:55 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i called AC and the guy said he has no idea what size it is.....what a dummy!
I didn't want to have to remove the fuel rail again because they leak when removed.....</TD></TR></TABLE>
Haha! You must have talked to Ivan, right?
I worked at AC Autotechnic for two years, no one there knows anything. They are all about show and that's one of the reasons why I left.
If it helps, Golden Eagle used to make AC's fuel rails. I dont know if they still do or if they are now getting them from Taiwan - but I bet the fittings are still the same as Golden Eagle.
And according to Golden Eagle's website:
-Precision CNC machined from 6061T6 billet aluminum
11/16” ( .6875 ) fuel bore for maximum fuel delivery on street or full race alcohol burning engines
- -8AN O-ring ( Boss ) ports provide huge flow capability
-Utilizes two ( 2 ) 1/8 NPT ( pipe ) ports for fuel pressure gauge or fuel pressure sending unit. Also comes with two
( 2 ) 1/8” NPT plugs
-Allows use of stock fuel pressure regulator
Comes with stock Banjo fitting adapter and plug for “bolt-on” applications
-Optional fittings:
- -6 AN fitting Part# GAN100-6
- -8 AN fitting Part# GAN100-8
- -10 AN fitting Part# GAN100-10
Hope that helps point you in the right direction.
Old Feb 26, 2008 | 07:25 AM
alscrx's Avatar
Default Re: AC AUTOTECHNIC fuel rail fitting size needed.... (CARMA_626)
Yeah that guy was an idiot, Just trying to sell me another ac fitting when i don't need it, I need an AN size,LOL.......
Ok, so i guess i'll try the 8AN....thanks
Old Feb 27, 2008 | 08:05 AM
alscrx's Avatar
Also heard since its a 5/8" bore, They could have used a 5/8 npt fitting!!!
But only thing is 5/8 could be..
5/8-18
5/8-20
So i can't order 3 or 4 fittings online....i need the correct size. Why is this so hard?
Someone has to have done this with that rail!
Old Feb 27, 2008 | 11:27 AM
ironcheftony's Avatar
go to home depot and go to there pipe/fitting section and see which 1 fits, then u will know
alscrx
Nov 11, 2009 02:52 PM
alscrx
10
Mar 5, 2008 11:42 AM
alscrx
Feb 18, 2008 08:01 AM
alscrx
Feb 17, 2008 01:47 PM
