full-race bar hitting pulley
Old Feb 17, 2008 | 01:12 PM
yz125rider21's Avatar
Default full-race bar hitting pulley
I been hearing some clunking noise here and there and I was installing my new full race radiator finally and saw where it was coming frmo and the bar to lower control arm is hitting the pulley!!!anyone ever seen that before???i will post pics after I get some new batteries for my digital cmaera.
Old Feb 17, 2008 | 02:33 PM
crx2nr822's Avatar
Default Re: full-race bar hitting pulley (yz125rider21)
That happened to my friend with his H22 crx but with an Explicit Speed bar......it started digging into the bar pretty bad I think he said he put some washers on it and it kept it from hitting it. But I think on rough bumps it still hits sometimes. How low is your car BTW?
Old Feb 17, 2008 | 03:14 PM
hamst3r3x's Avatar
I had the same problem and if you dont have power steering and ac just get the N1 type r pulley and youll be good but be carefull you dont want that arm to break
Old Feb 17, 2008 | 04:01 PM
crx2nr822's Avatar
Default Re: full-race bar hitting pulley (hamst3r3x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamst3r3x &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem and if you dont have power steering and ac just get the N1 type r pulley and youll be good but be carefull you dont want that arm to break</TD></TR></TABLE>
I would also recommend the CTR crank pulley to help with this problem, because the outer portion of my friend's H series crank pulley was what was tearing into the bar. If he had a single belt crank pulley like the Type S it would have solved his problems but they are a pain to find.....
Old Feb 17, 2008 | 05:36 PM
Crx Jimmy's Avatar
Default Re: full-race bar hitting pulley (crx2nr822)
I have a spare N1 pulley thats almost new if you end up needing one. I went superchaged and am using a ls one for more boost.
Old Feb 17, 2008 | 05:52 PM
Vince64's Avatar
Default Re: full-race bar hitting pulley (Crx Jimmy)
a friend of mine had one of his bars hitting the pulley. He was slammed though, dragging mudflaps
b20 in a ef wagon, solution was to switch to a b16 pulley for more clearance
Old Feb 17, 2008 | 06:16 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">I been hearing some clunking noise here and there and I was installing my new full race radiator finally and saw where it was coming frmo and the bar to lower control arm is hitting the pulley!!!anyone ever seen that before???i will post pics after I get some new batteries for my digital cmaera.</TD></TR></TABLE>
Raise yo ish up mang!
Old Feb 17, 2008 | 06:24 PM
honestly it isnt that low. but I will pm you Jimmy for about the pulley. Thanks guys I thought I was the only one had this problem ever, cause it is only the out part of the pulley hitting it.
Old Feb 17, 2008 | 06:28 PM
zrickety's Avatar
this same thing happened to me...is it the stock pulley? i installed the N1 (deletes power steering and a/c) and problem solved. i have since raised my car also, it's basically lowered just 1 inch. i've had no problems since the new pulley...i believe there are also smaller aftermarket pulleys that keep the PS and AC, and they should work as well
Old Feb 17, 2008 | 06:34 PM
Ya I just member seeing a few articles about those ctr pulley and werent so good. I just have a stock b20 with fullrace bar and hasport mounts with the pulley came on the b20, i only need the alt. pulley slot but dont want to ruine my motor either trying pulleys out.
Old Feb 17, 2008 | 07:42 PM
Vince64's Avatar
Default Re: (yz125rider21)
b16 pulley, im telling you
you have the exact same setup as my friend and he almost sawed his link in half
Old Feb 17, 2008 | 07:57 PM
Default Re: (Vince64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vince64 &raquo;</TD></TR><TR><TD CLASS="quote">b16 pulley, im telling you
you have the exact same setup as my friend and he almost sawed his link in half </TD></TR></TABLE>whats the diff between b16 and a b20 crank pulley they both have all 3 slots for belts...more details please
Old Feb 17, 2008 | 08:57 PM
143MYVTECEF's Avatar
get the n1 pulley from jdmland.com for $59.00. solved my problem with etd bar and itll solve yours too
Old Feb 17, 2008 | 10:24 PM
Vince64's Avatar
Default Re: (143MYVTECEF)
Locash was the one that told him about it
smaller overall diameter
Old Feb 18, 2008 | 06:06 PM
ef9_b20's Avatar
happened on b20 build. switch to ctr pulley. i put up with the grinding for a while though, it only did it when i was taking sharp turns
Old Feb 18, 2008 | 06:27 PM
zrickety's Avatar
Default Re: full-race bar hitting pulley (ef9_b20)
i have the B16 and the stock pulley was sawing it in half...go aftermarket or the N1
Old Feb 18, 2008 | 08:58 PM
ef9_b20's Avatar
Default Re: full-race bar hitting pulley (zrickety)
b16 swap now with stock pully doesnt rub yo
Old Feb 19, 2008 | 05:44 AM
ya I guess I will go the ctr pulley route until my new motor gets built.
Old Feb 25, 2008 | 05:54 AM
bought Jimmy pulley, can't wait to drive this on the road again!!!!seems like a forever project when working full time.
guy_from_nerk
26
Jun 23, 2008 08:01 AM
Acidcrakker
Nov 2, 2007 02:28 PM
5ohGT
Dec 18, 2004 12:25 PM
Red D Dragon
Mar 10, 2004 12:48 PM
Raocorp
14
Jan 10, 2003 05:48 AM
