Clearcoat peeling on Regamasters?
Guys, I have a problem. It appears that the clearcoat is coming off of my regamasters. The stickers are peeling in areas and I think it's related. Is there a way to fix this without having them all refinished?
Man that sucks, I don't think there is a way to fix it without refinishing them. This right here is the reason why pressure washer car washes don't touch my wheels. I wax them often also.
Those things haven't seen a pressure washer, just the end of a regular hose nozzle. I didn't notice the problem when I took them off the car in october, I just noticed it the other day.
thats mest. This is only an idea... but it MIGHT work. You could try masking around the area where the clear coat flaked and then spray a few new layers of clear. After that drys then maybe sand it with 1500 grit or wet sand it so it matches. Its only an idea, but its something to consider.
1000 or 2000 grit wetsand the clear off until its flat and smooth
won't it to last have them proffersiaonlly clear with the none scuff none mark clear coat by PpG
dave'sh22a4
Nov 2, 2002 05:37 PM
Warren
Dec 14, 2001 07:49 AM
