clutch problem in my civic
Old Feb 17, 2008 | 11:28 AM
92eghatchGSR's Avatar
Default clutch problem in my civic
i drive a 92 eg hatch with a 94 GSR swap in it well i was driveing the the clutch was makeing a loud vibrating nois only when i shifted or when i reved it up this has happend befor to my buddy befor i bought the car and the pressure plate came loose do you think it may be a bad pressure plate because he said when he put it on the 1st time the fins on it were all bent flat i orderd all new stuff i was just wondering if any one has had a problem like this befor it also will not go into gear when i put the clutch down any more but if i put it in 1st then start it with the clutch down it goes forword like the clutch is not disengauging i bled it and what not and thats not the problem so im hopeing my new clutch kit has somthing to do with it.
Old Feb 17, 2008 | 05:04 PM
DA_9's Avatar
Default Re: clutch problem in my civic (92eghatchGSR)
That sucks, prolly will fix the problem though. Could be shift linkage too bearings are gettin old with the combo of pressure plate. Time to do the dirty with it, oh yeah.
Old Feb 17, 2008 | 08:16 PM
Default Re: clutch problem in my civic (DA_9)
well my clutch and stuff came in today im replaceing the piolet berring throw out berring pressure plate and clutch im thinkin thats the problem pressure plate and throw out berring are just wore out
wearyfurball
13
Feb 23, 2008 07:08 AM
phoenixfire425
Aug 7, 2007 04:47 PM
teknohatchie91
Nov 28, 2004 07:54 PM
yellowturbo
Sep 20, 2004 12:10 PM
