POR 15
I just bought the starter kit and the filler. I have a shitty primer job because so expletivehead was supposed to paint it and flaked.
If ytou run into a guy named Ryan Burnett in portland, he is a tweeker and a theif and will rip you off.
Back to using this product. Any advice. I have some areas that have slight rust build up where the shitty primer is wearing. I am going to lightly sand and use the product. I have another area that ius developing A toothpick size hole AND RUST.
Ill post up some results. By looking at the webiste this stuff should be awesome. I got the idea off of here after looking around.
Thanks.
Thanks.
i am restorind an 81 trans am now that had some rust under the paint and stuff. you basically just read the instructions or call the guys there if you cant find the answer you are looking for. i a coating this whole car in por 15 then priming over it. you have to put down at least two coats with at least 2 hours in between coats. best to do it on a hot day. if you wanna use primer over that, wait two hours or so after the secound coat and prime with regular primer
