bondo??
Old Jan 15, 2008 | 10:57 AM
Blue00Si's Avatar
Default bondo??
i want to prep my car for paint and then take it to macco to do the paint job (i heard that they do a good job if you do the preping) on the small small little dents should i just use bondo to fill them? Do i need to wet sand the areas before i bondo them or just apply it straight to the paint?
Thanks
Old Jan 15, 2008 | 11:16 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: bondo?? (Blue00Si)
Take some time and read this thread. It will answer a lot of your questions.
https://honda-tech.com/zerothread/1962364
Old Jan 15, 2008 | 11:31 AM
Blue00Si's Avatar
thanks ya i started to read that after i posted it sorry!
Old Jan 15, 2008 | 05:25 PM
iam7head's Avatar
Default Re: (Blue00Si)
if it's not deep, just sand the area so the body filler have something to grab onto, fill it, and block that sucker. the general bondo thickiness is 3/8 inch so don't build a castle out of the polyester bastard
bondo brand stuff are junk just a friendly reminder, there's a reason why good filler cost 30 buck + for a qt.
zgrip
easy sand
poly flex
Modified by iam7head at 6:46 PM 1/15/2008
Old Jan 16, 2008 | 05:53 PM
newuser333's Avatar
Bondo/plastic body filler gets a bad reputation because of misuse. Not removing/correcting all rust, coats that are too thick, insufficient drying before painting, etc.
As far as dings - you can build paint up in those areas. Smoothly & evenly block sand with broad strokes until you start to see metal around the ding. Something like 280/320 grit wet. Then prime the area with a quality primer. Let it dry & do that again. And again.
If the dent is deeper than that, something like Red Lead can be used. It's basically a really thick/filler based paint that is put on with a putty knife. Sand it down after it's dry and then go through the prime/sand process.
Plastic filler can be used IF you sand the area with something like 120-180 dry paper and your filler coats are very thin - less than 1/8 inch after sanding.
Good luck! Oh - if you're going with MAACO, spend a little extra - you want acrylic enamel, not just enamel paint as a minimum. Otherwise the shine will be gone in less than a year. Acrylic can last up to 5 years if you wax it a couple of times a year.
MurtazaDSM
Paint and Body
Jun 1, 2011 11:08 AM
Si_chRis
Paint and Body
Aug 11, 2007 11:30 PM
drunknbass
Jun 6, 2004 09:03 PM
IDGAF2885
Sep 15, 2003 07:41 PM
LANEVOIX
Jan 26, 2003 04:43 PM
