spark and fuel still no start
ok I have spark and fuel and the car is almost turning over, what else can I check, would a bad ecu cause it to no start. Running out of ideas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi »</TD></TR><TR><TD CLASS="quote">well have u checked all your fuses?can u hear the main relay click?check all your grounds!</TD></TR></TABLE>
also see if the timing belt is on right.. some times that might be the problem. If you ecu go's out thin there be nothing working. spark, gass, will not work..if the main relay go's out thin there be no gass nor spark...some times it can be your spark chip in side your distrebuter.....sorry for the spelling.
some times that will go out but you will see some spark,,, the spark might be too week fur the car to run...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">Check your dizzy, TPS, and timing.....
Could be your timing belt is off a tooth.</TD></TR></TABLE>
dizzy,,,,,,,thats what i was thinking of...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">Could be your timing belt is off a tooth.</TD></TR></TABLE>
thats could cause your car not to start.try bring up number one piston reset your timing belt and go from there.
winquest1000
Jun 30, 2014 10:10 AM
TexasRoller
Aug 15, 2012 04:38 PM
illestrolla247
Apr 4, 2005 06:24 PM
