ef trailing arm problem **help**
Old Feb 17, 2008 | 09:30 AM
gordospeed's Avatar
Default ef trailing arm problem **help**
so i was pulling the rear trailing arms off of my civic today to put my Dc rear disc arms in and found that the toe adjuster bolt was frozen in the sleeve for the arm. i welded the sleeve to the arm to get the bolt to spin free and when it did the sliding nut (bracket whatever) inside the body of the car disappeared. what do i do to mount the new one? am i going to have to cut the floor out form the inside and actually put a nut on the bolt when i feed it through? has this happened to anyone else?... help!!!!
Modified by gordospeed at 7:23 PM 2/17/2008
Modified by gordospeed at 3:25 AM 2/18/2008
Old Feb 17, 2008 | 10:43 AM
Jdm91CR-X's Avatar
Default Re: ef trailing arm problem **help** (gordospeed)
Just below the rear seat, if you drill a hole in the floor you will be able to get to the nut. There is a small track for it to slide in, the nut just fell out. I had the same problem on my old hatch. Thats what I did for a quick fix.
Old Feb 17, 2008 | 10:47 AM
SIred91's Avatar
Rainman
Default Re: ef trailing arm problem **help** (Jdm91CR-X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm91CR-X &raquo;</TD></TR><TR><TD CLASS="quote">Just below the rear seat, if you drill a hole in the floor you will be able to get to the nut. There is a small track for it to slide in, the nut just fell out. I had the same problem on my old hatch. Thats what I did for a quick fix. </TD></TR></TABLE>
x2. WOW, what a good first post! for you!
O8 might have some good ones yet.
Old Feb 17, 2008 | 04:54 PM
Wilky's Avatar
Default Re: ef trailing arm problem **help** (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
O8 might have some good ones yet.</TD></TR></TABLE>
Lol! Seriously.
I had a similar problem when I stripped out the hole for the bolt for my rear LCA doing the "washer trick." Had to get a guy to bust open the rear subframe and tack a nut in there and tap it. It was a complete pita.
Old Feb 17, 2008 | 06:24 PM
gordospeed's Avatar
Default Re: ef trailing arm problem **help** (Wilky)
thanks guys, biggest bummer is that i just welded a new quarter and large floor section in the car. if i had known it would have made this way easier!!! looks like ill be doing some cutting next weekend.
Old Feb 17, 2008 | 07:30 PM
Targa250R's Avatar
be professional
https://honda-tech.com/zerothread?id=1619903
CRXguy_88
Mar 11, 2010 10:39 AM
bj113084
Jul 6, 2007 10:21 AM
hondamama7894
Jul 28, 2006 09:52 AM
ACE4DOOR
Aug 24, 2005 01:35 AM
Andy R
16
Jul 16, 2005 08:51 AM
