Honda S2000 Honda S2000
what tire size should i use?
Old Feb 17, 2008 | 08:47 AM
showtymers619's Avatar
* B A N N E D *
Default what tire size should i use?
i got 17x7 front
and 17x9 rear
also i noticed that the fronts normally run half a size higher on the profile
would is be bad to run the same profile front and rear?
Old Feb 17, 2008 | 09:01 AM
Black S2K's Avatar
my .2 would be a run a 225 front and 255 rear if the offset isnt too agresive
Modified by Black S2K at 1:14 PM 2/17/2008
Old Feb 17, 2008 | 09:09 AM
ricepicker's Avatar
Default Re: (Black S2K)
What are your offsets? That might also restrict what size tires you should run, I rub slightly with 245/40/17 on a 17X9 with a 45 offset, but my fenders are also rolled and I just rub where the quarterpanel connects to the bumper
Old Feb 17, 2008 | 08:08 PM
* B A N N E D *
Default Re: (ricepicker)
i tihnk the fronts are 35 and rear 45
so how about running the same profile on front and rear?
Old Feb 17, 2008 | 08:29 PM
NFRap1's Avatar
i had 255's w/+50 offset and rubbed constantly with shave rear fenders and bumper tab...it eventually started rubbing and melting my rear bumper believe it or not...id go with a 225fr and 245rr
f8onvtec
Oct 20, 2011 12:10 PM
kyeguy82
Honda S2000
Oct 7, 2006 02:01 PM
b18ef8
Honda S2000
Sep 8, 2005 09:35 PM
NightHawkC5
Honda S2000
20
Aug 21, 2003 03:51 PM
501 Lude
Aug 11, 2003 09:50 AM
