Trying to pinpoint low compressin...
Old Feb 17, 2008 | 08:44 AM
nemesis25's Avatar
Default Trying to pinpoint low compressin...
Thanks for reading. I recently, did a leak down test to pinpoint why I'm having low compression. The way I did it is, I pulled all the valve cover and all the spark plugs off and connected a 125psi air hose with a guage to cylinder in question. I also put the no.1 cyl at TDC but I'm a little stumped cuz air is coming out of the tailpipe and the no.2 sparkplug hole. I mean, I know why air is coming out of the tailpipe, cuz of Ex. valves not closing properly, but I cant figure out why air is coming out of the second cylinder. So, my question is am I doing the leakdown test incorrectly?
Old Feb 17, 2008 | 08:50 AM
98vtec's Avatar
moderator emeritus
Default Re: Trying to pinpoint low compressin... (nemesis25)
if air is coming out of the #2 cylinder when you are filling #1 then that tells me you have a busted headgasket.. If air is coming out of the exhaust and you are SURE that #1 is a TDC (arrows pointed up) then you have something wrong with the exhaust valves.
98vtec's Avatar
moderator emeritus
Default Re: Trying to pinpoint low compressin... (98vtec)
what were your symptoms or reason for doing a leakdown?
Old Feb 17, 2008 | 01:43 PM
nemesis25's Avatar
I bought the car with a misfire in cylinder 1.
Old Feb 17, 2008 | 08:31 PM
lude98SH's Avatar
Default Re: (nemesis25)
look for bubbles in the radiator neck. Look at the coolant and oil. Also look at the plugs. What color is the exhaust ? What does it smell like ?
What are the compression and leakdown numbers ?
Old Feb 22, 2008 | 06:46 PM
nemesis25's Avatar
Default Re: (lude98SH)
0 psi in cylinder 1. I had 210 psi in 2,3 & 4.
tundra2000
Jul 2, 2011 03:44 PM
drumminforev
Oct 20, 2006 07:40 AM
drumminforev
Oct 20, 2006 05:19 AM
GSR4door1
Apr 4, 2004 05:52 PM
B18EG6
Nov 18, 2002 08:54 AM
