H22 EM1 QUESTIONS PLEASE INFO NEEDED
Old Feb 17, 2008 | 05:09 AM
bosna1's Avatar
Default H22 EM1 QUESTIONS PLEASE INFO NEEDED
WELL AS YOU GUYS ALL CAN SEE I AM NEW TO HONDA-TECH AND I WAS WONDERING IF IT IS A GOOD IDEA TO PUT A H22 INTO A 00 CIVIC I WOULD ALSO LIKE TO KNOW WHAT KIND OF PROBLEMS WILL I RUN IN BECAUSE PEOPLE KEEP TELLING ME NEGATIVE OPINIONS SO I HAD TO COME TO THE BEST HONDA FORUMS AND ASK
HELP WOULD BE GREATLY APPRECIATED
Old Feb 17, 2008 | 05:27 AM
Boots's Avatar
Default Re: H22 EM1 QUESTIONS PLEASE INFO NEEDED (bosna1)
why are you typing in all caps?? and i personally wouldn't put an H series in an EK...i dont think its worth it, but thats just me
Old Feb 17, 2008 | 07:06 AM
Runnerdown's Avatar
If the install is done right and is high quality work then don't expect too many issues. Get some good axles.
Old Feb 17, 2008 | 09:18 AM
bosna1's Avatar
YEA I AM GETTING HASPORT AXLES WITH THE MOTOR I PURCHASED IT ON H-MOTOR ONLINE AND I PURCHASED HASPORT AXLES AND MOTOR MOUNTS
AND DO YOU GUYS THINK THERE WILL BE A DIFEERENCE CUZ I HAVE A 00 CIVIC SI AND THE STOCK B16 IS REALLY SLOW BUT YOU THINK IT WILL BE A BIG NOTICABLE DIFFERENCE
Old Feb 17, 2008 | 09:20 AM
98vtec's Avatar
moderator emeritus
Default Re: (bosna1)
take off caps lock.
Old Feb 17, 2008 | 10:49 AM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bosna1 &raquo;</TD></TR><TR><TD CLASS="quote">YEA I AM GETTING HASPORT AXLES WITH THE MOTOR I PURCHASED IT ON H-MOTOR ONLINE AND I PURCHASED HASPORT AXLES AND MOTOR MOUNTS
AND DO YOU GUYS THINK THERE WILL BE A DIFEERENCE CUZ I HAVE A 00 CIVIC SI AND THE STOCK B16 IS REALLY SLOW BUT YOU THINK IT WILL BE A BIG NOTICABLE DIFFERENCE</TD></TR></TABLE>
the biggest thing you'll probably notice is the extra tourque...and look at your keyboard, start at the top left corner, locate the esc button...the third button down from this is your caps lock...hit that button
Old Feb 17, 2008 | 01:22 PM
bosna1's Avatar
anyone elses opinion
Old Feb 17, 2008 | 03:17 PM
dohcteggie's Avatar
like said before, the torque is the main difference. if your looking for 1/4 mile times, my friend in an em1 went from i/h/e b16 - 14.9 to i/e h22 - 14.1&lt;---reference purposes only. handling may also suffer but that comes from the swap's added weight
Old Feb 20, 2008 | 12:14 PM
hqrshweg6's Avatar
Default Re: (dohcteggie)
i have an H22 and my opinion is to set up your suspension to handel it. My car has out handel Subes and many crazy cars out there so the myth about not handling is not really true to mine . i got Itbs and its a beast. i used to have a b16a which i luv, but like the people here says for 1/4 is great.
Good luck with yours
Old Feb 20, 2008 | 01:26 PM
2fastGSR's Avatar
King of the One Liners
Default Re: (hqrshweg6)
if you already had the b16 swap i would have sold the b16 motor- bought an h22 motor and a QSD H2b kit. used b16 trans, same mounts and called it a day.
Old Feb 20, 2008 | 03:18 PM
bossm's Avatar
Default Re: (2fastGSR)
yea well i have a h22 civic and it handles akward but when you get the right suspension it really helps it out a lot but yea for 1/4 times its a good motor
Old Feb 20, 2008 | 05:18 PM
hqrshweg6's Avatar
i had it in different cars, but i sold the one with the b16. it had a type r 4.78 gears jun flywheel, type r cams everything you can think of bolt ons. I just wanted to try the H22. heheheheheh
Old Feb 20, 2008 | 05:21 PM
hqrshweg6's Avatar
on my civic i had teins, energy bushings all around, type r sway bars, grs brakes, stainless brake lines, aem brake pads, strut bars, rear lower bar, it handel really well.
Old Feb 20, 2008 | 05:40 PM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hqrshweg6 &raquo;</TD></TR><TR><TD CLASS="quote">on my civic i had teins, energy bushings all around, type r sway bars, grs brakes, stainless brake lines, aem brake pads, strut bars, rear lower bar, it handel really well.</TD></TR></TABLE>
i have a hard time believing it out handled suburus
Old Feb 20, 2008 | 06:59 PM
hqrshweg6's Avatar
Default Re: (boots)
you can believe whatever you want but maybe they just slow down, but i still take them on the turns.
Old Feb 20, 2008 | 08:49 PM
2fastGSR's Avatar
too many noobs in this thread- cant tell which one is the OP and which is just randomly talking trash
Old Feb 22, 2008 | 11:39 PM
deucedeuceEK's Avatar
an h22 will straight up murda a b16......even when given head start
Old Feb 23, 2008 | 01:55 AM
bossm's Avatar
Default Re: (deucedeuceEK)
it is kind of hard to think you out performed a subaru but hey i am not doubting it
EJ-1
Aug 27, 2010 09:17 PM
The Destroyer
Apr 1, 2008 08:07 PM
vtec99ej
18
Aug 7, 2007 11:16 PM
delslowcoupeB16a
Jul 1, 2006 04:39 PM
cccya
Apr 25, 2002 04:19 PM
