timing belt tensioning
Old Feb 16, 2008 | 10:56 PM
supracrx's Avatar
Default timing belt tensioning
ok i'm doing timing belt on 98 civic LX. i already took off everything and now i'm just going to put the timing belt and tensioner on. i always have problem with putting the right tension on. so basically i install the tensioner on and put the bolt snug on it. then i put the timing belt from crank, tensioner, water pump, then the cam. after its all aligned, i spin crank counterclockwise till it moves 3 teeths and then i just loosen the tensioner and retighten?
when i first put the belt on, there will be slack on the front side (long side), and all tension is on the tensioner side?
Old Feb 17, 2008 | 02:52 AM
crazyguy's Avatar
Default Re: timing belt tensioning (supracrx)
yes.loose and retighten it.but most people also change water pump and tensioner when the replace a new timing belt
Old Feb 17, 2008 | 03:11 AM
instructor74's Avatar
Default Re: timing belt tensioning (crazyguy)
The bolt should be loose before you spin the engine counter clock wise 3 teeth then retighten the bolt. Also i would replace the water pump and tensioner.
Old Feb 17, 2008 | 09:06 AM
supracrx's Avatar
im changing everything timing belt, water pump, tensioner, drive belts, crank seal, valve cover gasket. the only thing i alawys have a problem with is tensioning the belt correctly
91 b20 integra
Sep 22, 2014 08:44 AM
dj-t
Feb 20, 2012 07:13 PM
zracer240
Aug 1, 2005 10:07 AM
SuicideSlide
Oct 15, 2004 10:06 AM
JaiDieM
Sep 11, 2003 06:55 PM
