AC AUTOTECHNIC fuel rail fitting size needed....
Old Feb 16, 2008 | 09:14 PM
alscrx's Avatar
Default AC AUTOTECHNIC fuel rail fitting size needed....
Does anyone know from experience the inlet fitting size on the AC Autotechnic fuel rail for the b motors???? It comes with a fitting for the stock banjo but i wanna use some AN fittings.
I needed to order some fittings for my braided steel hose setup.....i need to know the inlet fitting size please
Old Feb 17, 2008 | 11:13 AM
alscrx's Avatar
Default Re: AC AUTOTECHNIC fuel rail fitting size needed.... (alscrx)
Any help????
Old Feb 17, 2008 | 03:19 PM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACAutoTechnic.com &raquo;</TD></TR><TR><TD CLASS="quote">
AC fuel rails high volume fuel rails are CNC-Machined from t6061 billet aluminum. AC fuel rails feature a 5/8"-inch fuel bore capable of flowing he most fuel to support most high-performance engines than any other. This large bore dampens the back pulse for oversized high output injectors.
Easy to drill-completely compatible stock. AC fuel
rail comes with an additional port for nitrous set
up or for external - AC fuel regulators-easy
to install. AC fuel rails comes with fitting
to retain stock fuel lines.
you could have just looked on their website like I did.... wasn't hard to find
http://www.acautotechnic.com/main/
Old Feb 18, 2008 | 08:02 AM
alscrx's Avatar
Default Re: AC AUTOTECHNIC fuel rail fitting size needed.... (IT GUY)
Thats not the fitting size though......thats the inside diameter of the rail
Old Feb 18, 2008 | 08:39 AM
IT GUY's Avatar
edit: nevermind.
Modified by IT GUY at 12:57 PM 2/18/2008
Old Feb 18, 2008 | 08:44 AM
Hayasa15's Avatar
well i think most the fuel rails are a -6an so i would start there.
Old Feb 18, 2008 | 03:22 PM
alscrx's Avatar
Default Re: AC AUTOTECHNIC fuel rail fitting size needed.... (Hayasa15)
I called AC and the guy said he has no idea what size it is.....what a dummy!
I didn't want to have to remove the fuel rail again because they leak when removed.....
Old Feb 25, 2008 | 09:03 PM
alscrx's Avatar
Bump for help!
Old Feb 25, 2008 | 09:05 PM
408wdy's Avatar
usually aftermarket fuel rails are all -8..
Old Mar 5, 2008 | 11:34 AM
HamiltonRex's Avatar
Default Re: AC AUTOTECHNIC fuel rail fitting size needed.... (408wdy)
contact flamenco-t he knows his ****.
Old Mar 5, 2008 | 11:42 AM
alscrx's Avatar
Default Re: AC AUTOTECHNIC fuel rail fitting size needed.... (HamiltonRex)
PM'd him, Lets see if he knows
alscrx
Nov 11, 2009 02:52 PM
alscrx
Feb 27, 2008 11:27 AM
alscrx
Feb 18, 2008 08:01 AM
alscrx
Feb 17, 2008 01:47 PM
b18b98
May 24, 2002 05:42 AM
