non srs cluster in an srs car?
Hey, i have a 99 integra eqipped with SRS.. my current gauge cluster is a usdm gsr cluster.. it has the SRS light on it and i was wondering if i were to put in a cluster that didnt have the SRS light form an ITR is that would effect anything?
Im sure the ITR cluster is out of a newer integra because it has an abs light which the 96 spec did not.
Thanks for any help!
Well it shouldnt be a big deal,,all that would happen is that if your airbags went or anything happend to them..u just wouldnt have the light on ur gauge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by what gsr »</TD></TR><TR><TD CLASS="quote">Im sure the ITR cluster is out of a newer integra because it has an abs light which the 96 spec did not. </TD></TR></TABLE>
ok i have sort of a related question... when did integras start having ABS lights? cause my 95 ls doesnt, and i was thinking it may not be the orignal cluster...
Well all integras, all years, had abs except for the rs's. but they didnt make a light on the cluster until 98-01..atleast i believe so.
im not totally sure about that.. but my friend has a 95 gsr and it has an abs light becasue when he cut one of his cables it was on constantly.. so i kow that did.. maby ls didnt but i know his gsr does and its the orignal cluster.
It will be fine without the SRS light. But if you would like to keep it (96 spec ITR cluster), follow this guide...
https://honda-tech.com/zerothread?id=1836281
AW
Feb 15, 2005 08:11 AM
