'90 Civic - Gauge and A/C illumination question
The instrument panel and a/c control illumination lights have just started giving me problems on my '90 Civic DX. Of course, this only happens when I have the headlights turned on...the control panel lights are fine when I start the car up (and turn the headlights on), but they'll soon flicker and/or dim, and then die completely. However, they come back on whenever I use a turn signal...and then they die again as soon as my turn signal "clicks" off. I was first thinking that it could be a fuse problem, but now I'm not so sure. Maybe just a short or something in the wiring? If so, where do I look, and how do I go about it? Any help at all would be greatly appreciated.
Sounds like the stalk/light switch. All of your lighting is routed through it. If using your signals makes something happen, it's probably right there in the switch or the harness.
lilmarcEH3
Jan 28, 2010 04:29 PM
xsuperxsonx
Honda Civic (2001 - 2005)
Oct 17, 2009 04:35 PM
mrJDM_DB8
Oct 1, 2008 04:30 PM
