Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
tranny swap. quick questions
Old Feb 16, 2008 | 07:20 PM
JDMInspired's Avatar
Default tranny swap. quick questions
do i really have to use a manual ecu? because some people say you can use your at ecu
and can i use my at engine harness instead of using the mt harness?
also will the ex engine harness work on a lx motor?
Old Feb 16, 2008 | 09:41 PM
toyomatt84's Avatar
Sanji
1. I'd say it's not REQUIRED, but you'll probably throw a CEL for not having one.
2. Again, probably not REQUIRED, but you'll probably have excess wiring lying around that would normally go to the auto. transmission.
3. You'll have excess wiring there as well, but I think you could adapt it to work.
Old Feb 17, 2008 | 12:30 AM
Default Re: (toyomatt84)
thanks! anything else i should know wiring wise?
i heard that the key wont come out because the car will always think your in drive. how do i bypass that?
Old Feb 17, 2008 | 01:59 AM
toyomatt84's Avatar
Sanji
Default Re: (JDMInspired)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMInspired &raquo;</TD></TR><TR><TD CLASS="quote">thanks! anything else i should know wiring wise?
i heard that the key wont come out because the car will always think your in drive. how do i bypass that?</TD></TR></TABLE>
You'll need to disable the Immobilizer somehow.
Old Feb 18, 2008 | 09:35 AM
1llmatic's Avatar
New User
I think you could use an immobilizer bypass that security alarm systems use for remote start but it sounds like it would be alot of work.
Probably better off just going with a manual ecu.
I had to make sure that my AT shifter was set to P before I took it out when i did the AT to MT swap with my K20a swap.
JDM B20 EH2
Jan 16, 2012 07:40 PM
chrysanderson
Mar 24, 2011 05:42 PM
Slow93egg
Feb 5, 2007 08:33 AM
Supa_Slow_Civic
Jan 20, 2005 02:54 PM
Smokinsax
Aug 31, 2004 08:24 PM
