Oil filter change.....???
Does anyone know how to get at the oil filter to do a oil change myself on an Si sedan. I got the car up and see it but how the hell do you get at it? Do I need to take the wheel off?? Any help would be great!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 »</TD></TR><TR><TD CLASS="quote">buy the honda oil wrench cup and stretch your arms....have fun
I was afraid of that....so no real easy way to get at it.....
</TD></TR></TABLE>I was afraid of that....so no real easy way to get at it.....
Takes more work this way but does make life easier... take off the passenger side wheel and turn the steering wheel all the way to the left. You can see the filter and what you are doing. Make sure the entire front is lifted, meaning both tires are off the ground.
i do alot of oil changes on the new si at work and ive notice that when u turn the pass wheel it kinda helps but its still a pain to get the filter out without makin a really bigg mess...the honda oil filter wrench fits some other filters but i forget which ones cuzz there is too many out there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePirate »</TD></TR><TR><TD CLASS="quote">Does the honda oil wrench fit onto other oil filters? and if yes, has anyone tired it on a pure one filter?</TD></TR></TABLE>
same diameter size it will work, normally the cars i get at work have oem filter tho, for the few rare cases that they arent oem honda i got my trusty channel locks, but yeah worst honda filter to get to.
Man....I finally got that bitch off......I swear a gorilla at Honda must have put it on....It was so tight.....(thats what she said)....so this is what I did....I jacked the pass side up and put a jack stand under the sway mount....took off the pass tire....turned the wheel to the right all the way so I could get my arm in there....then took my trusty spring filter tool and worked the filter for about 15 minutes.....after that it was pretty easy....I took pics and will post a DIY later in spring.....
Thanks for everyones input!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatsi »</TD></TR><TR><TD CLASS="quote">Man....I finally got that bitch off......I swear a gorilla at Honda must have put it on....It was so tight.....(thats what she said)....so this is what I did....I jacked the pass side up and put a jack stand under the sway mount....took off the pass tire....turned the wheel to the right all the way so I could get my arm in there....then took my trusty spring filter tool and worked the filter for about 15 minutes.....after that it was pretty easy....I took pics and will post a DIY later in spring.....
Thanks for everyones input!</TD></TR></TABLE>
You should really use the proper jack stand points on your car. Don't make a DIY if it includes putting jack stands anywhere other than the proper points, because then you are just informing beginners, incorrectly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2008fijibluesi »</TD></TR><TR><TD CLASS="quote">
You should really use the proper jack stand points on your car. Don't make a DIY if it includes putting jack stands anywhere other than the proper points, because then you are just informing beginners, incorrectly.</TD></TR></TABLE>
Good point....I plan on doing a better DIY one in spring....it was 10 degrees out and I was doing a bit of trying not to freeze and get it done quickly.....a jack stand through the floor board is no fun...
Good point....I plan on doing a better DIY one in spring....it was 10 degrees out and I was doing a bit of trying not to freeze and get it done quickly.....a jack stand through the floor board is no fun...</TD></TR></TABLE>
Well...yea...that too...but I worry more about a kid dying trying to change his oil because he put his jack stand in an unsafe place.
dclub01
May 1, 2003 03:22 PM
