unplug my atts ecu
Old Feb 16, 2008 | 03:52 PM
aznoophi's Avatar
Default unplug my atts ecu
i unplug my ecu for my atts to take of the atts light i was wonder if thats a good thing to do and coulg i mess up my atts?
Old Feb 17, 2008 | 10:37 AM
Rob97'SH's Avatar
Default Re: unplug my atts ecu (aznoophi)
I did the same thing (removed more like it) but I'm also running Hondata. But haven't notice anything other then having an extra 50 lbs on the front end.
Old Feb 18, 2008 | 03:44 PM
gstrudler's Avatar
Default Re: unplug my atts ecu (Rob97'SH)
You should be okay. My understanding is that when the ATTS control unit goes offline, the ATTS unit just becomes an open diff. However, why is your ATTS light on in the first place? If there is a problem with the ATTS unit then yes, you could mess it up. Have you checked the codes for the ATTS light?
Old Feb 18, 2008 | 04:21 PM
aznoophi's Avatar
Default Re: unplug my atts ecu (gstrudler)
its cuz i dropped my car..
Old Feb 19, 2008 | 06:07 PM
gstrudler's Avatar
Simply lowering your car shouldn't trip the ATTS system; mine is also dropped. Running a tire size different from stock or equivalent (plus-sizing is fine if you use the right ratio's; I'm on 17's) can also trip the ATTS (putting on your spare, for example, will do this). If it started happening right after you dropped it, it's possible one of the wheel sensors got unplugged or damaged. Do you know how to check the ATTS codes? This will give us a better idea what is actually wrong.
alperx
Engine Management and Tuning
Sep 4, 2011 08:35 PM
Coroner
Oct 22, 2006 02:01 PM
naptownrex
10
Apr 18, 2005 08:26 PM
B18C1CYA
Apr 17, 2004 09:00 PM
Sephro
Feb 28, 2003 09:33 AM
