should i use my stock gsr valves or aftermarket?
Old Feb 16, 2008 | 10:18 AM
KillAHonDa's Avatar
Default should i use my stock gsr valves or aftermarket?
hey guys im currently in the process of a turbo build and obviously on a budget, the block is built 82mm,sleeved, etc..... my power goal is 600-650 , my ? is will it be ok/safe to use my Stock gsr valves w/ supertech valve springs and ret. or should i get supertech valves... what would be the benefit if i use the supertech valves...thanks
Old Feb 16, 2008 | 10:57 AM
KillAHonDa's Avatar
.. come on guys i know some can shed some light on my ? .. please help
Old Feb 16, 2008 | 11:30 AM
Schister66's Avatar
Man U FTW
You could use the stock valves, valvesprings, etc, but at that power level, you'd be better off running an aftermarket valve train. What cams are you running?? If you're running something aggressive enough, you might not have a choice but to upgrade.
Old Feb 16, 2008 | 01:22 PM
KillAHonDa's Avatar
Default Re: (Schister66)
right know the plan is to use gsr cams, but i might invest in some itr's if i can find them.
Old Feb 16, 2008 | 01:23 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">You could use the stock valves, valvesprings, etc, but at that power level, you'd be better off running an aftermarket valve train. What cams are you running?? If you're running something aggressive enough, you might not have a choice but to upgrade. </TD></TR></TABLE>
he said he's gonna use aftermarket valvetrain..he was asking about the VALVES
Old Feb 16, 2008 | 04:58 PM
blinx9900's Avatar
Default Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">
he said he's gonna use aftermarket valvetrain..he was asking about the VALVES</TD></TR></TABLE>
are valves not part of the valvetrain? just an honest question not trying to argue...
Old Feb 16, 2008 | 05:49 PM
KillAHonDa's Avatar
still tring to get a straight answer...please anyone?
Old Feb 17, 2008 | 07:39 AM
631 Teggy's Avatar
Default Re: (KillAHonDa)
My suggestion would be a set of stainless valves. It's just smarter with the heat they will be seeing at 600whp...
Old Feb 17, 2008 | 12:08 PM
KillAHonDa's Avatar
Default Re: (631 Teggy)
ty
turboman2.2
Jul 4, 2010 10:08 AM
SOHCD16y8
Dec 30, 2006 10:21 AM
DC2 Mang
Jul 17, 2006 03:08 PM
LsBack
Sep 19, 2004 01:04 PM
choiboiracing
May 15, 2004 03:19 AM
