94 Accord Oil Pressure Switch
Old Feb 16, 2008 | 06:06 AM
billyrusa's Avatar
Default 94 Accord Oil Pressure Switch
Hello,
I am trying to replace the oil pressure switch. I found the switch, but cat not see it very well. It seems hard to disconnect the wire from the switch. I am afraid I will break something if pulling the wire hard. I would like to make sure the wire should be disconnected by simply pulling it out?
THanks,
Old Feb 16, 2008 | 06:12 AM
v4lu3s's Avatar
RTFM
why did you post this in the accord forum and the prelude forum?
Old Feb 16, 2008 | 06:46 AM
kulrevon's Avatar
Default Re: (v4lu3s)
There is a flat head screw . You need to take it out the wire has a ring terminal on it.
Old Feb 16, 2008 | 08:00 AM
vlang29's Avatar
Default Re: (kulrevon)
pull off the rubber cap and you will see the screw and ring terminal. Mine had a bolt with phillips in middle
Old Feb 16, 2008 | 10:01 AM
pentaq's Avatar
Default Re: (vlang29)
The Accord switch is different. Also has a different thread pattern. Tried this and it didn't fit.
JimRaynor90
Mar 2, 2015 05:41 PM
kwik eg hatch
Jun 24, 2010 01:21 PM
billyrusa
Feb 18, 2008 04:48 PM
southpass
Audio / Security / Video
Sep 2, 2003 08:07 AM
wwcivic
Sep 7, 2001 10:37 AM
