Cooling Fans
Old Feb 16, 2008 | 05:30 AM
CRX-1991's Avatar
Default Cooling Fans
Wireing a toggle switch to operate cooling fans, spliced wires at fan switch at the back of the block. Trying to use a lighted toggle switch. Can get fans to run but no light on switch. Can get light on switch but fans want run. Its for a 91 CRX Si. I have installed a D16Y7 this motor has no provision to hook up fans.
Old Feb 16, 2008 | 09:21 AM
Crx Jimmy's Avatar
Default Re: Cooling Fans (CRX-1991)
you are going to need a relay to get it to light up, the switch at the back of the block just grounds to turn the fans on, so on your switch you have 3 terminals, 2 should be + and one ground(made for switched +). you are switching the ground so you have 2 ground terminals one one + terminal. You will need the relay to switch the ground and then supply the needed + to the switch and relay.
Dazer 1991
Aug 27, 2012 03:26 PM
thundernoodle
Audio / Security / Video
15
Aug 6, 2010 06:05 AM
shackler
12
Jun 21, 2007 06:17 PM
85
Sep 3, 2006 03:02 PM
SigmaOmega
Jul 17, 2005 06:55 PM
