trottle body cleaning
Old Feb 16, 2008 | 04:40 AM
dragaholic's Avatar
Default trottle body cleaning
Did a spray out yest. of my TB. Now its idling around 1g. Will it sort it self out or can I adjust the idle screw get it back to stock idle.
I know there is a write up about this but I can't find the link.
Old Feb 16, 2008 | 05:23 AM
crazyguy's Avatar
Default Re: trottle body cleaning (dragaholic)
did u remove all the sensors when u clean the TB? like map sensor and tps sensor? if you do. u need a multi meter to adjust the tps sensor.
Old Feb 16, 2008 | 01:45 PM
dragaholic's Avatar
Default Re: trottle body cleaning (crazyguy)
nope. Just took off the intake tubing and sprayed inside the TB. Also I had the car runing and sprayed behind the TB as well. There is on miss or surging just idling at 1g.
Old Feb 16, 2008 | 01:51 PM
crazyguy's Avatar
ok.adjust the throttle idel screw .
Old Feb 17, 2008 | 03:16 AM
dragaholic's Avatar
thanks.
So from what I read let the car warm up, un-plug the iacv and adjust to desired rpm?
Old Feb 17, 2008 | 03:09 PM
dragaholic's Avatar
ttt.
Also do I have to jumper the service connector when doing the adjustment?
elli
Jun 1, 2010 01:22 PM
crfr230
Apr 24, 2007 07:48 PM
dc4_wHORE
Sep 26, 2006 04:34 PM
mikeunreal
Oct 26, 2005 05:31 PM
snouka
Oct 15, 2004 02:02 PM
