Alternator belt keeps flying off?
Old Feb 15, 2008 | 08:49 PM
02Type-S's Avatar
Trades A lot!!
Default Alternator belt keeps flying off?
Fixed, the crank pulley had a chip that was shredding the belts. A new one is on and everything is ok.
Modified by 02Type-S at 2:19 AM 5/26/2008
Modified by 02Type-S at 6:08 AM 5/27/2008
Old Feb 15, 2008 | 08:57 PM
LastGenEK's Avatar
Default Re: Alternator belt keeps flying off? (02Type-S)
I dont think there is a pulley, it should go right from the harmonic balancer straight to the alternator.
What do you mean the pulley isnt lining up?
Old Feb 15, 2008 | 09:10 PM
02Type-S's Avatar
Trades A lot!!
Default Re: Alternator belt keeps flying off? (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK &raquo;</TD></TR><TR><TD CLASS="quote">I dont think there is a pulley, it should go right from the harmonic balancer straight to the alternator.
What do you mean the pulley isnt lining up?</TD></TR></TABLE>
Im talking about the pulley on the alternator (the whole alternator is not at the right angle for the pulley on it to align with the crank pulley).
Old Feb 15, 2008 | 09:54 PM
axeldc2's Avatar
check your alternator
Old Feb 15, 2008 | 10:07 PM
tofast2belast's Avatar
Default Re: Alternator belt keeps flying off? (axeldc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axeldc2 &raquo;</TD></TR><TR><TD CLASS="quote">check your alternator</TD></TR></TABLE>
wow what an obvious reply....
to the OP. it could be like you said alternator not ligning up correctly. are you using the bracket, alternator,alternator pulley, for that engine or did parts come from different motors?
the belt could be kinda loose too, does it squeel at all?
Old Feb 16, 2008 | 06:51 PM
02Type-S's Avatar
Trades A lot!!
Default Re: Alternator belt keeps flying off? (tofast2belast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofast2belast &raquo;</TD></TR><TR><TD CLASS="quote">
the belt could be kinda loose too, does it squeel at all?</TD></TR></TABLE>
thanks for the first logical post, lol. Im using the alternator and parts from a 97 gsr and the built motor in my car is a 97 gsr so that should not be the problem. I checked the tension on the belt and adjusted it really tight, loose, and about every possible position and i still have the problem. Is there some sort of a bushing in the lower bracket? Someone told me it may have not been put back in when we swapped the motors and that it would make the alternator and pulley be at an angle.
Old Feb 16, 2008 | 06:53 PM
crazyguy's Avatar
there is no bushing on the alternator bracket. are u using the oem nuts and locking bolt?
Old Feb 16, 2008 | 07:04 PM
dragonfly2k3's Avatar
Default Re: Alternator belt keeps flying off? (crazyguy)
Maybe you should add a bushing. I cant think of the harm by adding a large washer or two to get the two pulleys to line up. Is the pulley on the crank not seated correctly?(does it wobble when turned?)
Old Feb 16, 2008 | 07:11 PM
are you using the correct belt? some belts are 3 ribbed and some are 4 ribs, look at the pulley and and look at the belt.
Old May 25, 2008 | 07:46 AM
cnmyteg's Avatar
02Type-S im trying to contact you about your SI for sale but im a trial user so I cant post in FS forums... can you email me at tnnrelzbth0920@aol.com
Delano5050
Jul 5, 2007 07:47 PM
mickiemagik
Mar 29, 2007 04:11 PM
TrueZen
May 2, 2005 03:20 PM
(__________)
Sep 23, 2002 06:46 AM
PatrickGSR94
Jan 13, 2002 10:27 AM
