Restored some OEM 99-00 Civic headlights
So I bought a pair of 99-00 OEM Civic headlights from a friend for cheap...and they were hazy so I decided to wet sand and polish them...results came out pretty good.
***Edit:***
Here is a quick review of what I did... it is really simple and short.
1) Well first you need rubbing compound that removes swirls, you also need polish and wax, an applicator, microfiber towel, spray bottle with water, and 2000 grit wet sanding paper.
2) Take headlights off the car (if they are on your car).
3) Once the headlights are off, you can begin wet sanding.
4) Basically spray the headlight with water and start sanding it all over evenly until it is all hazy and smooth (you can tell by feeling it while it's wet).
5) Dry and clean the headlights very nicely...notice that they should be hazy.
6) Apply rubbing compound with the applicator and work it into the headlight.
7) Then wipe it off with the micro fiber towel the same way you did as you applying the compound.
8) Then apply polish and wipe it off the same way as you did with rubbing compound.
9) Then apply wax to the headlights and wipe it off.
10) I applied each product (rubbing compound, polish, wax) twice to get better results. But you can do more to also, doesn't hurt...just let the products haze up before wiping it off.
11) If the headlight is still a bit hazy after you applied the stuff, you need to keep wet sanding more, and then repeat the steps 5-10 again.
Stuff I used:
Before:
Wet sanded with 2000 grit:
End result:
Modified by Si_chRis at 9:04 PM 2/16/2008
Modified by Si_chRis at 9:05 PM 2/16/2008
Modified by Si_chRis at 9:08 PM 2/16/2008
Modified by Si_chRis at 9:09 PM 2/16/2008
Modified by Si_chRis at 9:10 PM 2/16/2008
***Edit:***
Stuff I used:
Before:
End result:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX »</TD></TR><TR><TD CLASS="quote">Thought it was a little DIY write-up type thing but was wrong. Ya bought a lot and skipped a lot of steps lol
Came out nice. </TD></TR></TABLE>
yeah...I didn't expect the results I got either since I did it by hand and not a buffer...and it only took me about an hour too...about 10-15min of wet sanding per headlight...and the rest was the polishing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NMZ »</TD></TR><TR><TD CLASS="quote">they will rehaze if you dont keep reapplying the compound right?</TD></TR></TABLE>
I'm not sure...I think it does but I don't know.
I'm planning on selling these locally since I already have JDM SI-R's on my car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX »</TD></TR><TR><TD CLASS="quote">Post pictures of those please. Idk what 99-00 SiR's look like. </TD></TR></TABLE>
heres are some pics...basically the same as oem but no amber reflector but it has a city light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBear »</TD></TR><TR><TD CLASS="quote">Nice work. </TD></TR></TABLE>
thanks
thanks
I had the same thought
I'm looking forward to doing mine after seeing the after pictures.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK tommy »</TD></TR><TR><TD CLASS="quote">nice job
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ramon96LS »</TD></TR><TR><TD CLASS="quote">Nice job! So what did you use first? Compound? then?
Make it a mini write up </TD></TR></TABLE>
I mainly did this based on the "wax on wax off" procedure after I wet sanded with 2000 grit.
I used rubbing compound twice, then the polish 3 times, then wax 3 times. I just kept pressing hard into the headlight each time I was wiping the stuff off with the microfiber towel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michael123 »</TD></TR><TR><TD CLASS="quote">make a write up please mine are all yellow need to restore them asap </TD></TR></TABLE>
I added steps in the first post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djole_V »</TD></TR><TR><TD CLASS="quote">thats pretty good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si_chRis »</TD></TR><TR><TD CLASS="quote">
I added steps in the first post.</TD></TR></TABLE>
thanks man i did it looking sweet...
Smells like Tuna
di an old set of mine.. they came out real nice.. but it removes all sort of protective finsh and makes some haze a month or so later! or for me it did.. but i rec. putting a clearcoat on them afterwards prolly!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burke420 »</TD></TR><TR><TD CLASS="quote">di an old set of mine.. they came out real nice.. but it removes all sort of protective finsh and makes some haze a month or so later! or for me it did.. but i rec. putting a clearcoat on them afterwards prolly!</TD></TR></TABLE>
Use this after every wash or so on the lights-
