Pheonix Gold Amp CHEAP!!!! Best offer gets it.
It was in my aunts Porsche running her MB Quart speakers. She sold the Porsche and gave me the amp because I was going to install door speakers but now my car is for sale. It went for a decent amount when she purchased it. Best offer takes it I want it gone.
XS4300 model
4 Channel Mosfet Amplifier
PWM Mosfet Power Supply Defeatable
Advanced Overload and Thermal Protection
Dual Hi Level Input Connections
Advanced Muting Circuitry Eliminates Turn-On And Turn-Off Noises
Metal Film Capacitors/Resistors In Signal Path
24kt Gold Plated High Current Power And Speaker Terminals
Isolation Mounting Feet
Optional XS Link For Seamless Multiple Amplifier Installation
Dual Low Pass level control
Frequency Response +/-1dB, 20Hz to 20 kHZ
Signal to Noise Ratio (A-weighted) >100dB
Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
Nominal Continuous Power per Channel @ 1 % THD 35 Watts x 4 into 4 ohms @ 14.4 Vdc
IASCA/USAC Power Rating 12 Watts x 4 into 4 ohms @ 12.5 Vdc
Minimum Load when Bridged 2 Ohms
Minimum Load per Channel 1 Ohm
Input Signal Voltage Range 0.1 volts to 2 volts
Crossover Type Resisitor Network, Linkwitz Riley,
Highpass/Lowpass
Crossover Slope 24 dB per octave
Crossover Frequency Range 20-550Hz
Factory Crossover Setting 85 Hz
Auxilary Output Channels 2
Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Speaker Output
Bass Boost 0- to +18dB @ 45 hZ
Power Supply Voltage 10Vdc to 15.5Vdc
Recommended Fuse 40 amp
Dimensions 12.25L x 9.25W x 2.10H
Modified by Indiana Jones at 10:32 PM 2/17/2008
XS4300 model
Highpass/Lowpass
