Stock B16B + 10K RPM REDLINE ???
Old Feb 15, 2008 | 05:52 PM
BIG T's Avatar
Default Stock B16B + 10K RPM REDLINE ???
ok let me first say that i have searched.
wondering if some could possibly enlighten me upon what is needed to make a stock B16B rev to 10K rpms ????
now i know that i am going to need to head and such.
although is there anything else that i am going to need????
Old Feb 15, 2008 | 05:57 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Stock B16B + 10K RPM REDLINE ??? (BIG T)
and why do wee need to go to 10k RPM?
Old Feb 15, 2008 | 06:24 PM
Hatch99's Avatar
cause at 10k the secodary Vtech kicks in
just playin
Old Feb 15, 2008 | 06:34 PM
.I.Need.Money.'s Avatar
Default Re: Stock B16B + 10K RPM REDLINE ??? (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">and why do wee need to go to 10k RPM?
To gain status on tha streetz.
Old Feb 15, 2008 | 07:25 PM
Ass$nyper's Avatar
Default Re: Stock B16B + 10K RPM REDLINE ??? (93EGB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
To gain status on tha streetz. </TD></TR></TABLE>Silly me. Lost track of time, I forgot Race Warz is coming up
Old Feb 15, 2008 | 07:43 PM
Ross 2.0's Avatar
In a Junkyard near you.
I guess nobody told you guys that floating valves is the newest JDM trend?
Old Feb 15, 2008 | 08:26 PM
Hatch99's Avatar
no the newest JDM trend is jerking off while your driving Thats how you build boost up faster
Old Feb 15, 2008 | 11:37 PM
BIG T's Avatar
Default Re: Stock B16B + 10K RPM REDLINE ??? (Hatch99)
cuz i wanna run vtec killer cams and utilize a fuller rpm band, for road racing.
Modified by BIG T at 12:49 AM 2/16/2008
Old Feb 16, 2008 | 12:07 AM
wbaldwin_86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch99 &raquo;</TD></TR><TR><TD CLASS="quote">no the newest JDM trend is jerking off while your driving Thats how you build boost up faster</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil M0nkey &raquo;</TD></TR><TR><TD CLASS="quote">I guess nobody told you guys that floating valves is the newest JDM trend?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">Silly me. Lost track of time, I forgot Race Warz is coming up </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
well if you are serious about road racing there is a potential to reving that high at this altitude
(5280+) if you can make power up there. The main thing that you will need is valve train components … don’t listen to these dumb *** kids… if you make power up there do it.
THE MAIN THING IS IF YOU MAKE POWER!!!
Old Feb 16, 2008 | 12:22 AM
Default Re: Stock B16B + 10K RPM REDLINE ??? (wbaldwin_86)
here you go....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toda &raquo;</TD></TR><TR><TD CLASS="quote"> TODA valve springs allow maximum lift while preventing valve float, which can occur under high rpm, high lift conditions. Their specific spring rate prevents damage to TODA camshafts, which may occur as a result of using valve springs that are too stiff. Valve springs that are too stiff may also put additional stress on the timing belt and cause shredding and breakage. TODA valve springs are oval shaped, which increase load capacity by 20% and reduce weight by 15% compare with conventional round shaped valve springs.
Old Feb 16, 2008 | 07:54 AM
SiB16A's Avatar
lol
Old Feb 16, 2008 | 08:01 AM
b19coupe's Avatar
If you want to make power at 10k RPM you will need a great header. You will need a good ported head. You will need some very large camshafts. You will need an intake system that provides lots of air. A well balanced rotating assembly will also help. A clutch that does not explode at high rpm might be nice too.
Why you would want to rev a motor to 10k is another question.
martyball619
Aug 16, 2007 12:06 PM
under_the_hood
May 11, 2007 05:12 AM
accord03coupe
Honda S2000
17
Mar 27, 2007 03:28 PM
civicnar
Feb 18, 2004 07:14 PM
b16a2EG6
Jul 27, 2003 10:58 PM
