steps for painting new hood
Old Feb 15, 2008 | 03:16 PM
projectef's Avatar
Default steps for painting new hood
can anyone tell me the step by step for painting my hood. i never painted with a spry gun before. my hood got mest up, so i bought a brand new hood (black)
Old Feb 15, 2008 | 09:37 PM
iam7head's Avatar
Default Re: steps for painting new hood (projectef)
is it primered?
if it's already primered then you can jut clean it up and shoot bc and cc over it
Old Feb 16, 2008 | 04:48 AM
powerflow's Avatar
Default Re: steps for painting new hood (iam7head)
The black finish is the factory primer/ e-coat. The part still needs to be sealed w/ a primer sealer. Clean the part and inspect for defects/damage, then fix prior to preping.
Abrade the part w/ 500 on a DA. scuff the edges and underside.
Set up the part so you can paint both sides or cut in the underside first. Blow off all dust. Clean w/ wax/degreaser and a water based prep cleaner if you have any. Tack.
Spray sealer, base , then clear.
Old Feb 16, 2008 | 01:19 PM
projectef's Avatar
yup its the black finish primer (shiney) so i just have to clean the hood, spry primer, the paint, clear coat, then buff and wax it right?
Old Feb 16, 2008 | 02:06 PM
powerflow's Avatar
Default Re: (projectef)
Sounds like you don't know much at all about painting. Do some google searching and read as much as you can, you will learn alot about the basics. The part has to be sanded before you apply the sealer. Fresh paint needs to fully cure before you wax, typically 45-90 days is the recommended range before waxing is ok. Don't rush into it if you don't know what your doing, practicing on scrap panels would also help.
Old Feb 17, 2008 | 09:19 AM
pushintealhondas's Avatar
Default Re: (powerflow)
where did you get your hood from? Just wondering because i want a new hood because of a non-fixable dent. I looked online at one and I just want to see where you got yours from.
Old Feb 19, 2008 | 04:03 PM
projectef's Avatar
eco, in R.P. CA (north bay)
Jmjr1000
Paint and Body
Aug 4, 2012 07:40 AM
blb2397
Paint and Body
27
Jun 4, 2012 11:23 AM
EK9Tune
Paint and Body
12
Sep 6, 2008 04:22 PM
Nameless Warrior
Paint and Body
Feb 14, 2008 09:37 PM
l
Aug 6, 2002 10:45 AM
