plug wires??
Old Feb 15, 2008 | 12:33 PM
prolifik22's Avatar
Default plug wires??
well i went to do a tune up and remove my spark plug wires...when i went to remove the wires they were kinda stuck..so i went to put some force in it and come to find out there like burn in the spark plug tubes ...havein trouble gettin them out due to them bein burnt in there...
my question is that if anyone would know what can cause this ??
kinda fishy to me ...and also what i can do to avoid this ever happin again..
application in a 94 honda ex...with a ls/v
thnx for the relplys
Old Feb 15, 2008 | 12:58 PM
Perfectionist's Avatar
Default Re: plug wires?? (prolifik22)
Applying some silicone dielectric grease to the ends of the spark plugs and/or the wire connectors will help make future removal easier. As for the burn you mention, your description isn't clear. Is it on the outsides of the tubes on the wires, inside, in the spark plug bore, etc?
Old Feb 15, 2008 | 02:09 PM
prolifik22's Avatar
inside the walls where the wires plug on to the plugs were they make contact is where it burnt..
Old Feb 16, 2008 | 10:42 AM
prolifik22's Avatar
anyone else have this happin!!!
Old Feb 17, 2008 | 05:28 PM
prolifik22's Avatar
bump
Old Feb 18, 2008 | 07:05 AM
NEeradicator's Avatar
Default Re: (prolifik22)
I'm going through the same thing. Looks like there's a gap between the plugs and the wire. The arcing is causing the rubber to melt. Mine isn't melted, but it's burnt pretty good. I've tried all the brands in stock from the auto retailers and still have the same issue. There's no "click" when I put the wires on, so it's just sitting on top on the plug. Heading over to Honda and buying their spark plugs and wire set. Hopefully, it works. I could try NGK wires and plugs, but since the wires are special order I wouldn't be able to return them. ...stay tuned!
Old Feb 22, 2008 | 11:30 PM
prolifik22's Avatar
yea thnx for replyin and i actually got all of the boot out .....but yea got it started and havent really ran it but yea ill see if the problem occurse again
JDM_SOHC
Apr 30, 2007 02:24 PM
97LXAcc0rd
Aug 14, 2005 01:34 PM
slickrc
Aug 3, 2005 06:39 AM
wannakno
Nov 26, 2002 08:32 PM
TDRacing
Jul 18, 2002 10:58 AM
