MT et drag slicks 22.5 / 8 / 13 ( advise needed)
I'm planning on running my EF with B16a at the track soon. Mods are 75 shot wet nitrous system, upgraded fuel, and ignition. I'll be running on some 22.5 / 8 / 13 MT et drag slicks on some 13" bogarts. What is the optimum tire pressure and launch rpm for these slicks. I was thinking setting the tire pressure at 12 psi and launching @ 5500 RPM . Feed back / advice is greatly appreciatted. Thanks
off topic Im running a crx all motor with same tire and one piece front end wings west sides. Im haveing a problem with the slicks hitting if a turn the wheel all the way if i have the car sitting low. the higher the better clearance I have. I have the tube front cross member ajusted al the way up wtf
so if i run my mt i have to have the car raised up. **** it going to look like i have a lift kit. cool for the info if i lower a have to run m and h 22's?
