NEED HELP ON ELECTRIC PROBLEM?
I GOT A 99' CIVIC EX, The light on my dash and all the electrical things start flashing, when I was driving on second the started to idle at the ridum of the flashing of the lights, this happens mostly when I put the car into first gear than if I put it into neutral it stops, it also burns my speedometer fuse. Say I change it and im driving the speedometer works right, than when the things starts flashing burns the fuse out again. Anybody has an idea of what might be happening?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAZARD_1310 »</TD></TR><TR><TD CLASS="quote">I GOT A 99' CIVIC EX, The light on my dash and all the electrical things start flashing, when I was driving on second the started to idle at the ridum of the flashing of the lights, this happens mostly when I put the car into first gear than if I put it into neutral it stops, it also burns my speedometer fuse. Say I change it and im driving the speedometer works right, than when the things starts flashing burns the fuse out again. Anybody has an idea of what might be happening?</TD></TR></TABLE>
Check your engine harness under your intake manifold.There is a honda bulletin about it i think its 99-029.Right under the intake manifold there is a bracket that holds it to the block,which tend to rub against the engine harness causing it to short out and blowing the #15 fuse check it out and hit back on us if it doesnt help.Get under your car and check the engine harness
G/L
G/L
and if it is that wiring that is causing all that, just buy that plastic wire covering **** and cover that part up and black tape that **** up...also zip tie it away...gl man
FFFreddYYY
Apr 11, 2008 07:20 PM
