My Si wont start
Old Feb 14, 2008 | 11:35 AM
Kid_SiR's Avatar
Default My Si wont start
Ok guess here the deal i HAve a 91 si with a sohc an u throw on a trbo kit i had too put the battery in the back then the promblem im having is it wont start with the key if i take the wire that gose too the started then if i put a lose wire in there then tap it too the postive the car with start wat canit beee there enought ground on the motor i have 4 of them
Old Feb 14, 2008 | 12:03 PM
sgallagher's Avatar
Default Re: My Si wont start (Kid_SiR)
WHAT?
Did you use large enough battery cables? Did you take the ground off the engine/trans? Im not really sure I understand.
Old Feb 14, 2008 | 12:29 PM
Malgerus's Avatar
Default Re: My Si wont start (sgallagher)
Can you retype that in proper English?
Old Feb 14, 2008 | 12:38 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: My Si wont start (Malgerus)
I'm from Texas..Allow me to interpret..
He has got a madd-tyte JDM Si sohc with a turbo..
The battery was re-located to the back of the car and
now the damn thing won't start..
Beats all he ever did see..
If you are having to "jump" a positive wire to the starter,
then the ground is not the problem..
I would suspect the inhibitor switch that is attached to the clutch pedal
is the most likely cause..
Old Feb 14, 2008 | 12:51 PM
Kid_SiR's Avatar
noo the car starts just not withthe dam key if u goo too the dam engine bay an if u look too see were the starter is there is a signal wire if u remove that wire an put one end of a wire there an jump it too the batttery it will start with out it it dosent
Old Feb 14, 2008 | 12:55 PM
88DXCRX's Avatar
Default Re: (Kid_SiR)
Then the problem is in the starter signal circuit...
as stated above..
Old Feb 16, 2008 | 01:42 PM
sgallagher's Avatar
Default Re: (88DXCRX)
This ^^ is correct..follow the diagram and you should find your problem.
Old Feb 16, 2008 | 02:32 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Ok guess here the deal i HAve a 91 si with a sohc an u throw on a trbo kit i had too put the battery in the back then the promblem im having is it wont start with the key if i take the wire that gose too the started then if i put a lose wire in there then tap it too the postive the car with start wat canit beee there enought ground on the motor i have 4 of them </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid_SiR &raquo;</TD></TR><TR><TD CLASS="quote">noo the car starts just not withthe dam key if u goo too the dam engine bay an if u look too see were the starter is there is a signal wire if u remove that wire an put one end of a wire there an jump it too the batttery it will start with out it it dosent</TD></TR></TABLE>
Can anyone honestly read that? Holy cow.
Anyway, the answer is your neutral safety switch or 'inhibitor switch'
Honda knowledge
Apr 2, 2015 11:37 PM
B16a2Em1
Mar 17, 2011 08:53 PM
samvilay
May 11, 2010 04:36 PM
luv2boost
Oct 25, 2008 06:47 PM
oc_civic
Apr 10, 2008 06:33 PM
