RSX ECU differences
I'm in the process of possibly switching out from an AEM EMS to a Hondata Kpro on my s2000 for emissions purposes.
As some of your might or might not know. The s2000 KPro utilizes an RSX ecu. Now the ECU that Hondata uses is a PRB A01-A12. I am finding conflicting articles/reports/threads with some saying this is from the base model, and others saying that it's from the type-s.
Can anyone confirm for me which model I would be able to find this ecu on?
Secondly; there are a few other parts I need to pick up in order to get this setup to work on the s2000. Mainly sensors. Which RSX model are these from? or are they universal between both base and type-s models?
Crank sensor 37500-PZX-003
Crank wheel 13622-PCX-013
TDC sensor 37510-PZX-003
TDC wheel 14112-PCX-003
Valve cover 12310-PCX-020
Drain plug washer (for PCV valve) 94109-14000
Check out their website. http://www.hondata.com/ecus.html Look at the list it's from a 02-04 RSX TYPE-S.
As far as the parts. Look them up at http://www.acuraoemparts.com
PRB A01-A12 is the ECU in the 2002-2004 RSX-S. As for the other parts, I would guess they would have to come from a RSX-S, but if I were you, I would ask Hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Slayer »</TD></TR><TR><TD CLASS="quote">PRB A01-A12 is the ECU in the 2002-2004 RSX-S. As for the other parts, I would guess they would have to come from a RSX-S, but if I were you, I would ask Hondata.</TD></TR></TABLE>
Ok, so it is from a type-S.
The customer service at Hondata isn't the best, I keep getting placed on hold and no help as to the extra Honda parts that are needed.
I've done a couple searches with the part numbers and haven't come up with anything. I'll give the link (http://www.acuraoemparts.com) posted above a try to track these parts down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5RickK20 »</TD></TR><TR><TD CLASS="quote">call church's tuning in CA i know they work alot with the k-pro in the s2k ask for the owner sean church he has an s2k himself </TD></TR></TABLE>
HyperPrinting
36
Jul 29, 2002 01:01 PM
