DOT R-Compounds....what's written on your sidewall?
Most (if not all) DOT r-compound tires have a warning or disclaimer stamped on the sidewall. I'm trying to get a sample of what each make/model has indicated.
If you can run to your basement, garage (or living room for those of you who live in apartments
) and check the wording on your tires and post up the make and model along with the phrase, I'd appreciate it!
I believe most Hoosier models have "Not for highway use"
Thanks!
) and check the wording on your tires and post up the make and model along with the phrase, I'd appreciate it!I believe most Hoosier models have "Not for highway use"
Thanks!
DOT approved tires are not going to have this statement on them. That is the whole point of the DOT approval.
All DOT R compounds will have some sort of tread. Even if its just two grooves around the tire. See a picture of a Kuhmo V710.
I dont think hoosiers are DOT approved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gunns »</TD></TR><TR><TD CLASS="quote">DOT approved tires are not going to have this statement on them. </TD></TR></TABLE>
They do.
All DOT R compounds will have some sort of tread. Even if its just two grooves around the tire. See a picture of a Kuhmo V710.</TD></TR></TABLE>
What does this have to do with the question I asked?
Hoosier A3S303, R3S03, A3S04, R3S04, A3S05, R3S05, A6, R6 are all DOT approved.
They do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16chaos »</TD></TR><TR><TD CLASS="quote">my a6s say competition use only, dot j79j radial there sitting in my kitchen</TD></TR></TABLE>Great place to keep them!
Thanks.
Thanks.
I have Hoosier A6s, Kumho V710s, and Avons in my garage and will probably load some of each into my car Saturday, if nobody has reported back by then...
I found a few others doing some digging.
Nitto NT01
sidewall reads: "recommended for competition use only"
sticker reads: "not intended for highway use"
Hankook Z214
sidewall reads "for competion use"
Toyo RA1
Anyone got some old Kumhos (Ecsta v700 or Victoracer), Yokos (A032 or A048) or some old Hoosiers? I'll check my 710s tonight and post them tomorrow.
Nitto NT01
Hankook Z214
Toyo RA1
Here in Ontario we have a law about tires that are not legal for road use.
http://www.e-laws.gov.on.ca/ht...e.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
Highway Traffic Act
Code de la route
R.R.O. 1990, REGULATION 625
TIRE STANDARDS AND SPECIFICATIONS
7. (1) No person shall operate on a highway a motor vehicle, trailer, device or apparatus equipped with tires that,
(a) bear the words “not for highway use”, “farm use only” or “competition circuit use only”
(c) bear any other wording or lettering indicating that the tire was not designed for highway use;
Many enthusiasts choose to drive RA1s, A032, A048 and other DOT R-compound tires on the street. It's always good to know if your car complies with the local laws.
What do you think an officer would do if he pulled you over and saw "for competion use" stamped on your tires?
Highway Traffic Act
Code de la route
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanbaifo »</TD></TR><TR><TD CLASS="quote">225/50-15 Why?</TD></TR></TABLE>
Thanks!!!!
Thanks!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13inches »</TD></TR><TR><TD CLASS="quote">Here in Ontario we have a law about tires that are not legal for road use.
What do you think an officer would do if he pulled you over and saw "for competion use" stamped on your tires?</TD></TR></TABLE>
If thats the only reason, a hot iron would melt that warning right off.
A cop would pull you over, pop your tires and make you push the car home uphill.
I honestly dont think many cops even bother to check on something like that unless it's obvious you're running slicks or so.
ElectronBlueGSR
Dec 6, 2003 11:58 AM
