90 hatch si jdm b16a
Old Feb 14, 2008 | 12:13 AM
Jayponce's Avatar
Default 90 hatch si jdm b16a
I have a 90 hatch si with a jdm b16a b16 cable tranny and a chipped b16 ecu. Question, is it bad to drive this car untuned? It seems to be running a little lean. Vtec engages at 5k rpm good or bad? redlines @ 8500 rpms. What tranny can i swap in instead of this cable crap i need hydro! i know an ls tranny would do how about the tranny out of the 2000 si? What do i need for the 0bd0- 0bd1 conversion?
[img=http://img404.imageshack.us/img404/3962/pic0209088gc3.th.jpg]
Old Feb 14, 2008 | 07:12 AM
dr_latino999's Avatar
Default Re: 90 hatch si jdm b16a (Jayponce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce &raquo;</TD></TR><TR><TD CLASS="quote"> chipped b16 ecu. </TD></TR></TABLE>
Is this a proper basemap which is a replication of the OEM B16 maps or is this one of those "Super-JDM-Mugen" $10 deals off E-Bay?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce &raquo;</TD></TR><TR><TD CLASS="quote">It seems to be running a little lean. </TD></TR></TABLE> How are you measuring A/F? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce &raquo;</TD></TR><TR><TD CLASS="quote">What tranny can i swap in instead of this cable crap i need hydro!</TD></TR></TABLE> Unless you do a custom Hydraulic system install, any other transmission you install will still be activated one way or another by a cable. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce &raquo;</TD></TR><TR><TD CLASS="quote">What do i need for the 0bd0- 0bd1 conversion? </TD></TR></TABLE>
OBD-1 ECU
OBD-1 Distributor
OBD-1 Jumper Harness (Which can be purchased - Rywire - or done yourself -D.I.Y. / FAQ - OBD-0 --&gt; OBD-1 Pinouts and Conversion Help )
Old Feb 14, 2008 | 07:27 AM
wickedEFguy's Avatar
A cheap upgrade would be a Fuel pressure regulator and turn up the PSI on it a little.
Maybe upgrade the fuel pump too?
Old Feb 14, 2008 | 09:13 AM
Jayponce's Avatar
Its a tune able chip, Yea new fuel pump sounds good running the stock 90 civic pump right now.
I'm measuring air/fuel by guessing.
(puff of white smoke) the spark plugs are a bit toasted. the ngk plugs are only about 5 months old.
Old Feb 14, 2008 | 09:20 AM
sgallagher's Avatar
Default Re: (Jayponce)
Get a PR3 ECU dont mess with it. It was designed by some pretty smart engineers to run that engine to the best of its ability.
I would suggest not trying to measure A/F ratio by guessing.
As far as you puff of white smoke, you might want to do a leak down/ compression tests sounds like you got some oil in the combustion chamber. I have seen valve seals leak quite often on the old b16's.
Old Feb 14, 2008 | 10:07 AM
wiZCo's Avatar
Stouts 'n' Scotch
How can you guess afr?
I'd suggest getting the basemap redone or getting a whole new ECU.
Old Feb 25, 2008 | 05:25 PM
Jayponce's Avatar
Default Re: (wiZCo)
SOLD IT
Old Feb 25, 2008 | 05:30 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce &raquo;</TD></TR><TR><TD CLASS="quote">SOLD IT </TD></TR></TABLE>
GOOD. You shouldn't own a "tuner", asking the kind of questions you have asked.
Go get a Tiburon.
Old Feb 25, 2008 | 05:45 PM
Smokinsax's Avatar
The Boot
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
Go get a Tiburon.</TD></TR></TABLE>
Mr Si_Vtec
Northern California (Sales)
Apr 19, 2007 02:52 PM
hondachris1994
May 23, 2006 10:48 AM
jdmjoelol
28
Apr 13, 2006 07:13 AM
VNTEC
May 27, 2004 03:47 PM
Kp_VtekNiks
Apr 23, 2002 11:41 PM
