gsr trans fix or ls trans
my gsr lsd trans needs to be repaired. my question is should i repair the gsr trans or should i just replace it with a ls lsd trans that has nothing wrong with it and is there a big difference diveability or performance?
id fix your gsr ive had a few ls trannies and they are JUNK,nothing wrong with the ls but gearing is so long....hope that helps...also what needs repaired? did you see how much someone will charge you? and what are you using the tranny on?
just a gsr with 4-1 headers, v2 intake system. i talked to someone and they said it sounds like a shift fork. $400 to just look at the trans.
