bpi stack and filter
Old Feb 13, 2008 | 06:13 PM
NorthernXposure's Avatar
Default bpi stack and filter
just recieved my bpi stack w/ k&n filter and installed it... and even attatched to the stock intake arm it is a world of difference from the comptech drop in and stock box. throttle response is 10x's better and it definitly breaths much better in the top end. ill have the set up on an aem cold air set up as soon as my buddy digs the intake out of storage.
i cant believe what i was missing out on... and with my current set up the motor definitly breathes deeper.. wish i had some dyno figures but thats not going to happen till summer..
for the bpi product.. it took a little while to get up here. but you can expect that living in alaska
Old Feb 14, 2008 | 12:31 AM
gsrious's Avatar
bpi stack... thumbs up.
im lovin' mines.
Old Feb 14, 2008 | 02:54 AM
jdm_teg_gs's Avatar
Bpi stack is awesome, had it for about 6 months on mine, then switched to the comptech icebox. I was getting tired of the heatsoak with that huge filter.
Old Feb 14, 2008 | 05:30 AM
jomama's Avatar
Default Re: (jdm_teg_gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_teg_gs &raquo;</TD></TR><TR><TD CLASS="quote">Bpi stack is awesome, had it for about 6 months on mine, then switched to the comptech icebox. I was getting tired of the heatsoak with that huge filter.
funny seeing another BPi thread in the same week! i've had concerns about heatsoak, but i think it'd be minimal. ...just look at the dyno sheets on BPi's site. i also have the comptech icebox and i haven't run that setup yet, but it think it'd be tit for tat. i've also seen member BSQ's 4" "icetake" setup similar to the mugen (albeit, DIY quality) and i'll probably run that instead of the comptech when it's all said and done. one setup that would be interesting to see is the oem arm/bpi stack/K&N RU-1048 filter, and the bottom part of the icetake setup so that you'd have the benefits of the velocity stack/K&N filter setup with the cold air benefits of the icetake setup. granted, you won't have the vacuum effect drawing air in since it wouldn't be sealed between the two, but if you were to run this on the track and took off the front right turn signal and had the inlet of the icetake tube right at the opening of the turn signal acting like a ram horn, it'd work.
Old Feb 14, 2008 | 08:54 AM
Default Re: (jomama)
no heatsoke here... it 15 degrees and dropping lol..
but im sure it will happen. im gonna have the set up on a aem cai befor too long though..
Old Feb 14, 2008 | 02:31 PM
jdm_teg_gs's Avatar
Heatsoak is pretty noticebale in the summer when the BPI after a half an hour or so of driving. Don't get me wrong, BPI stack is a great product, but maybe the dyno's were done on a cool engine. I could really tell on the butt dyno, when the engine was cool. It also doesn't help that I have the T1R header giving off all the heat.
The homemade icebox idea sounds good too. I'm going to try and use the bpi stack on a custom k&n filter inside the icebox. I just haven't found the right filter yet to accept the comptech pipe.
Old Feb 14, 2008 | 02:36 PM
coolhandluke's Avatar
Pictures or ban
Old Feb 14, 2008 | 09:43 PM
clem kevin's Avatar
should one get an air/fuel tune after installing one of these?
Old Feb 15, 2008 | 05:42 AM
jomama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_teg_gs &raquo;</TD></TR><TR><TD CLASS="quote">Heatsoak is pretty noticebale in the summer when the BPI after a half an hour or so of driving. Don't get me wrong, BPI stack is a great product, but maybe the dyno's were done on a cool engine. I could really tell on the butt dyno, when the engine was cool. It also doesn't help that I have the T1R header giving off all the heat.
The homemade icebox idea sounds good too. I'm going to try and use the bpi stack on a custom k&n filter inside the icebox. I just haven't found the right filter yet to accept the comptech pipe.</TD></TR></TABLE>
you'd have to find a really, really unique filter to:
1. mate up correctly with the BPi velocity stack
2. fit into the OEM or comptech icebox
...you may end up having to fab up a custom icebox out of fiberglass or something somewhat easy... when and if you get it together...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolhandluke &raquo;</TD></TR><TR><TD CLASS="quote">Pictures or ban </TD></TR></TABLE> and DIY instructions
Old Feb 15, 2008 | 02:25 PM
jdm_teg_gs's Avatar
Ive been searching for a while now for the exact dimensions of the filter I need on the K&N site. I've come close, but nothing exact. I'm going to keep with the icebox, I don't really have time to fab up a custom one. When I find a filter the same size as the comptech foam one, I'll let you guys know.
Old Feb 17, 2008 | 01:03 PM
pics added.. excuse the dirty engine bay!
also got tired of the noise and pulled off the buddy club spec2.. and threw on my tanabe ultra medallion but hacked of the big fart can and welded up a vibrant oval muffer with a 2.5 in and 2.5 out.. sounds great and looks great..
Old Feb 17, 2008 | 01:23 PM
GO-FIGHT-KILL's Avatar
I gained 5.05whp/7.43ftlbs over CAI with a 3" SRI/BPI/K&N.
Old Feb 17, 2008 | 10:52 PM
ITR.#1446's Avatar
Default Re: (GO-FIGHT-KILL)
hey i just bought a bpi velocity stack off a member on here where can the filter be purchased?
Old Feb 18, 2008 | 08:03 AM
verticle's Avatar
Default Re: (ITR.#1446)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">hey i just bought a bpi velocity stack off a member on here where can the filter be purchased?</TD></TR></TABLE>
http://www.bpinitiatives.com/products.php
Old Feb 20, 2008 | 07:43 PM
usctyper's Avatar
Default Re: (verticle)
I found this http://www.inlinefour.com/blravestfi.html
It's a lot cheaper.
Old Feb 20, 2008 | 09:00 PM
vivid 02's Avatar
Default Re: bpi stack and filter (NorthernXposure)
I use one for the Race Track but mine is setup out of the headlight.
Of course only for the track though or I might swallow up a bird
Old Feb 20, 2008 | 09:18 PM
jomama's Avatar
Default Re: (usctyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usctyper &raquo;</TD></TR><TR><TD CLASS="quote">I found this http://www.inlinefour.com/blravestfi.html
It's a lot cheaper. </TD></TR></TABLE>
not a bad deal. you can just buy the BPI velocity stack straight from BP Intitiatives (or HT like i did) and get the RF-1048 off Amazon http://www.amazon.com/gp/product/B00062ZNEA for 40 shipped or off HT for less (like i did )
Old Feb 21, 2008 | 05:13 AM
I need a recommendation on where to pick up the sleeve/coupling to mount the BPI on my SRI. I was a and didn't order the full bundle.
Old Feb 21, 2008 | 05:35 AM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">
apparently it was molded out of a desktop garbage can...I'm pretty sure just hacking one up will do the trick too.
Old Feb 21, 2008 | 06:27 AM
Default Re: (RagingAngel)
Any pictures of that setup? I'd like to see the bottom, I'm assuming its opened ended. Its almost comical but so simple in thought process/design.
Old Feb 21, 2008 | 07:29 AM
jomama's Avatar
Default Re: (coolhandluke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolhandluke &raquo;</TD></TR><TR><TD CLASS="quote">Any pictures of that setup? I'd like to see the bottom, I'm assuming its opened ended. Its almost comical but so simple in thought process/design.</TD></TR></TABLE>
x2. "comical" doesn't even cut it. screw it... i'm stealing that idea. what i would proably do is somehow "cap" off the top of the trash can so you could create a better vacuum, though.... then you can have a trash can lid to throw stuff away or store stuff.
Old Feb 21, 2008 | 07:31 AM
the top is actually sealed against the hood with some foam normally...
Old Feb 21, 2008 | 07:33 AM
white rocket's Avatar
Hey look, it's the Endyn bathtub CAI . I tried to create something like that out of CF but it looked horrible. -2 show points
Hey Pat
Old Feb 21, 2008 | 08:14 AM
jomama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">the top is actually sealed against the hood with some foam normally... </TD></TR></TABLE>
like styrofoam?
Old Feb 21, 2008 | 01:08 PM
like styrofoam?</TD></TR></TABLE>
I doubt it, styrofoam wouldn't handle heat very well.
