Other Honda/Acura Model Injectors
Old Feb 13, 2008 | 06:07 PM
MDKid's Avatar
Default Other Honda/Acura Model Injectors
Anyone know what other model Honda/Acura vehicles fuel injectors can fit in a 2000 Accord i.e. RSX or TSX (just example models) Im runnin nitrous and I wanna get bigger sized injectors but before I look at RC injectors I wanna see if other vehicles injectors could fit in ours!
Old Feb 13, 2008 | 06:11 PM
TheMuffinMan's Avatar
He knows where you live!
The RDX Acura *might* I know Rosko Racing uses them with the H22 EuroR IM's
Old Feb 13, 2008 | 06:21 PM
hondadude's Avatar
Default Re: Other Honda/Acura Model Injectors (MDKid)
this link might help you..... bottom of the page there is an injector list.
http://www.accordinglydone.com/data/
Old Feb 13, 2008 | 09:24 PM
MDKid's Avatar
2000 Accord 4cyl, F23 motor and that AccordinglyDone link didnt help!
Old Feb 13, 2008 | 09:39 PM
Derek128's Avatar
Default Re: (MDKid)
i guess its 235cc as well
Old Feb 14, 2008 | 03:36 AM
TouringAccord's Avatar
H-T Order of Merit
what size (flow) injectors are you looking for? I assume you are looking to stay peak/hold?
Old Feb 14, 2008 | 03:38 AM
MDKid's Avatar
Yeah I guess I misworded everything, but I want bigger size flow injectors and I was wonderin if the RDX, or RSX injectors which I know are bigger would work!
Old Feb 14, 2008 | 03:41 AM
H-T Order of Merit
Default Re: (MDKid)
whats their flow rate?
and are they peak/hold or saturated injectors?
Old Feb 14, 2008 | 04:29 AM
MDKid's Avatar
Okay did some research, the RDX flow rate is 410cc but im still checkin to see if there peak/hold or saturated!
Old Feb 14, 2008 | 05:23 AM
GhostAccord's Avatar
Default Re: (TouringAccord)
I'm not 100%, but don't the 98-02 Accords use low imp injectors?
Old Feb 14, 2008 | 05:38 AM
H-T Order of Merit
Default Re: (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">I'm not 100%, but don't the 98-02 Accords use low imp injectors?</TD></TR></TABLE>
I believe so...
peak/hold = low impedance
Old Feb 14, 2008 | 05:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
I believe so...
peak/hold = low impedance </TD></TR></TABLE>
My bad I meant to say High impedance... late night last night .......
Should have read like this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">I'm not 100%, but don't the 98-02 Accords use [b]High[/] imp injectors?</TD></TR></TABLE>
Old Feb 14, 2008 | 05:44 AM
H-T Order of Merit
hmmm... I though they used the peak/hold. I'll do some searches and see what I find.
Edit:
I can't find anything yet so I searched for some parts to see if the 98-02 Accord would list a resistor box and couldn't find one so they may be high impedance = saturated. Anyone know for sure?
Old Feb 14, 2008 | 05:45 AM
MDKid's Avatar
Okay guys I found this on k20a.org and I think im gonna try this, I believe it should work the same way for us!
http://www.k20a.org/forum/show...ge=13
Old Feb 14, 2008 | 05:46 AM
H-T Order of Merit
Default Re: (MDKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDKid &raquo;</TD></TR><TR><TD CLASS="quote">Okay did some research, the RDX flow rate is 410cc but im still checkin to see if there peak/hold or saturated!</TD></TR></TABLE>
do you need that large? Just wondering, I'm not sure what you would need. But if you do want that large, why not get some DSM injectors? I think you have to slightly modify the plug but other than that they fit, and I think you can probably find them cheaper. That is of course if you are looking for peak/hold injectors.
do you recall if you have a resistor box located under the hood for the injectors? I believe on the 94-97 Accord it was near back of the driver side strut tower. If you have one, you have peak/hold injectors.
Old Feb 14, 2008 | 05:55 AM
MDKid's Avatar
I have 75 and 100hp jets on my nitrous kit, I switch them on the track from time to time! I heard though that you have to switch to ob1 when using dsm injectors!
Old Feb 14, 2008 | 06:01 AM
H-T Order of Merit
Default Re: (MDKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDKid &raquo;</TD></TR><TR><TD CLASS="quote">I heard though that you have to switch to ob1 when using dsm injectors!</TD></TR></TABLE>
to be honest I'm not sure...
Do you know what your injectors are? peak/hold or saturated?
Old Feb 14, 2008 | 06:23 AM
MDKid's Avatar
peak/hold
Old Feb 14, 2008 | 06:26 AM
H-T Order of Merit
Default Re: (MDKid)
ok, so they are peak/hold then?
well, I know the 92-96 H22 injectors are ~325cc and peak/hold and would fit no problem. Not sure if thats enough for what you want or not.
Old Feb 14, 2008 | 06:30 AM
MDKid's Avatar
Im still weighing all my options but I appreciate all the help! I thought I would get bashed for posting a thread about this on H-T!
Old Feb 14, 2008 | 06:50 AM
H-T Order of Merit
Default Re: (MDKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDKid &raquo;</TD></TR><TR><TD CLASS="quote">I thought I would get bashed for posting a thread about this on H-T!</TD></TR></TABLE>
cigrafix2
Nov 13, 2007 10:32 AM
got_boost16
Feb 21, 2006 08:04 PM
clu
May 14, 2003 12:27 AM
baonest
May 20, 2002 09:11 AM
