Motor oil in intake tube?? help me out
Old Feb 13, 2008 | 05:56 PM
Efcivicfukalex's Avatar
Default Motor oil in intake tube?? help me out
i just took off my air filter and i have allitle oil at the end of the pipe??? whats that mean?? also would obd 2 injectors and bad spark plugs and clutch *** Vtec up???
Old Feb 13, 2008 | 06:00 PM
Jakester9500's Avatar
Default Re: Motor oil in intake tube?? help me out (Efcivicfukalex)
a little oil is normal. the little breather hole (forget technical name) has a hose running into your intake tube, which would allow the oil into your intake tube. Don't stress unless there is a **** ton of oil in there.
obd2 injectors in what? what motor are you running with which obd2 injectors? if the spark plugs are bad, why are you using them in the first place?
Old Feb 13, 2008 | 06:10 PM
SOHC_4dr's Avatar
those wont mess up VTEC. its very difficult to mess that up
Old Feb 13, 2008 | 07:01 PM
instrument's Avatar
i think you need to figure out exactly what vtec is.
asking that question is like asking can dirty carpet make your milk go bad.
Old Feb 13, 2008 | 07:54 PM
Schramm's Avatar
The three words you're looking for are Positive Crankcase Ventilation there Jakester9500.
most stock honda motors use the vacuum created in the intake manifold to suck debris out of your crankcase, so its normal. If you want to get rid of it i suggest an oil catch can, better for your engine cause then all that crap isn't re-routed back into the firing cylinders...
Modified by Schramm at 12:13 PM 2/14/2008
Old Feb 13, 2008 | 08:00 PM
JDM Dylan's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">i think you need to figure out exactly what vtec is.
asking that question is like asking can dirty carpet make your milk go bad.</TD></TR></TABLE>
LMAO!!!
Old Feb 13, 2008 | 11:08 PM
catch can huh ok ls vtec ls tranny seems like it needs a tune up tho
Old Feb 14, 2008 | 10:51 AM
Default Re: (Schramm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schramm &raquo;</TD></TR><TR><TD CLASS="quote">The three words you're looking for are Positive Crankcase Ventilation there Jakester9500.
Modified by Schramm at 12:13 PM 2/14/2008</TD></TR></TABLE>
okay, good deal. Thanks
bmanuhutu
Jan 28, 2010 07:31 PM
Toda Party
Apr 14, 2009 04:05 AM
JDMcb7
Apr 24, 2005 10:31 PM
Touch
May 31, 2003 11:05 AM
SjCiViCHB
Dec 22, 2001 10:18 PM
